Abs & dsc code........help
Old Sep 16, 2014 | 04:58 AM
Xtype steve's Avatar
Default Abs & dsc code........help
I was driving my cat the other day and my ABS & DSC lights came on. I pulled over to check the break fluid and the the cap to the break fluid reservoir had loosened and came off. I filled it to the proper level ask it was a little low and replaced the cap with a new one and the ABS & DSC light still come on and goes back off periodically. There seems to be no real rhyme or reason as to when or why it is still coming on, the breaks don't feel spongey or different either. HELP PLEASE......I cannot afford to take it to Jaguar at this present time........
Old Sep 16, 2014 | 07:30 AM
Tennscott's Avatar
It would help if you could get a code from the OBD. Could be several things: dirty wheel sensor, sensor going bad, bad connection in the sensor wire, ABS computer going bad or a bad wheel bearing.
I would check wheel sensors, and connections on the wire lead that connects to the wheel sensors on the front. If you have a code reader try to get a code.
I had an intermittent light and I had to have my ABS computer repaired.
Scott
2004 X-type
Old Sep 16, 2014 | 10:36 AM
gmcgough's Avatar
If the and light is blinking it will usually be a 2 digit pattern. That might give you more information.
Old Sep 16, 2014 | 01:15 PM
dwclapp's Avatar
Steve: The thread below contains a trick by Thermo to display error codes thru your instrument panel.
https://www.jaguarforums.com/forum/x...sg-ctr-125457/
Also, most major auto parts stores will check your error codes as a free service.
Old Sep 16, 2014 | 04:06 PM
Thermo's Avatar
Veteran: Navy
Steve, odds are, your check engine light should have come on too. Get the codes read and post them here. We can give you a lot of information from those codes. Right now it is hard to say what is your problem without some more information.
radiatn
Jul 2, 2021 04:45 PM
kingdom worker
Nov 14, 2020 03:47 PM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
