Abs engages when making right turns
Old Oct 22, 2015 | 03:29 PM
millertic's Avatar
Default Abs engages when making right turns
About 1 month after I changed my brake pads and rotors my abs started engaging with light braking, after s bit the abs light would come on. I had it scanned and came up with the right from abs sensor, swapped it with a new one and no change at all. It now seems that it won't do it unless I am making a right turn and then it engages.
I am thinking a bad reluctor ring but don't wanna tear it apart if somebody thinks it might be something else.
Old Oct 22, 2015 | 08:58 PM
clyons's Avatar
I assume you meant the right front abs sensor. You should check the wiring to the sensor. Sounds like it gets strained in a turn. The reluctor rings are only in the rear. The equivalent on the front is included in the bearings.
Old Oct 24, 2015 | 11:35 AM
millertic's Avatar
I'll check the wiring good one more time, I have also noticed since my brake job that the right front tire is wearing on the inside and the car has been pulling left pretty good which it never did before.. Maybe entirely unrelated though.
Old Oct 24, 2015 | 11:46 AM
Doug's Avatar
My X-type experience and knowledge is nil, but, just to throw something out.....
I had a problem with my XJR where the ABS light came on only around corners. Long story short....
The reluctor wheels is pressed onto the hub. A worn rear wheel bearing caused excessive movement of the hub...particularly when cornering... allowing the reulctor to move away from the sensor, disrupting the reading. On disassembly for wheel bearing replacement I also discovered the reluctor wheel was loose on the hub. On reassembly I used Loctite to ensure it didn't wobble.
Old Oct 25, 2015 | 08:42 AM
millertic's Avatar
In doing a little more research, it looks like the wheel bearing is tied to the abs system, is it possible that the uneven wear, pulling and abs issue is related to a bad bearing in the front right? I have been getting a weird high pitched noise but I thought it was my carrier bearing.
XJ8JR
92
Jun 2, 2016 01:35 PM
bcucharternet
Oct 21, 2015 08:16 AM
xkeots
Oct 18, 2015 08:59 AM
jagnation89
Oct 17, 2015 01:48 PM
hstovall1
Oct 17, 2015 09:32 AM
