ABS and Knuckle replacement
Old Feb 24, 2007 | 06:49 AM
chillicop's Avatar
Default ABS and Knuckle replacement
I had to replace the passenger side Knuckle. Now my ABS light is on. Any thoughts on a fix?
Old Feb 24, 2007 | 07:18 AM
BuckMR2's Avatar
Default RE: ABS and Knuckle replacement
Thought you got the answer here:-
On this other site
[sm=yikesomg.gif]
Old Feb 24, 2007 | 07:24 AM
chillicop's Avatar
No Buck, the bearing was never removed (that I know of)and it is the ABS light, and the ABS wire is not cut. I really like the experienced members on this forum, and decided to post here. I only received (2) replieson the other forum.Do you know what codes indicate ABS. I tried to find a post from Racer, that had the OBM codes, but I could not find it.
Old Feb 24, 2007 | 07:43 AM
BuckMR2's Avatar
Some codes here:-
https://www.jaguarforums.com/m_1506/tm.htm
Old Feb 24, 2007 | 07:54 AM
chillicop's Avatar
Buck, do you know if the front end has speed sensors, or are these just in the rear spindles?
Old Feb 25, 2007 | 08:25 AM
BuckMR2's Avatar
ORIGINAL: chillicop
All 4 wheels have speed sensors.
Old Feb 25, 2007 | 01:20 PM
chillicop's Avatar
Thanks fellas, that will be my first check.
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
pocketrocket
Sep 3, 2015 07:44 PM
innzane
Sep 2, 2015 10:08 AM
