ABS LH driver side speed wheel sensor
Old Apr 23, 2012 | 11:00 PM
Noxparadise's Avatar
Default ABS LH driver side speed wheel sensor
Is the speed wheel sensor hard to replace? I already had the speed wheel sensor ring replaces and the code is still coming up C1175 the driver side speed wheel sensor, if anyone has info on this i greatly appreciate it.
Thanks,
JAMES
Old Apr 24, 2012 | 06:46 AM
Thermo's Avatar
Veteran: Navy
Replacing the speed sensor is easy. Remove the wheel, undo a plug, remove a bolt, slide the sensor out. Install is the reverse.
You may want to also look at the wiring, specifically where the wiring goes into the body of the car. We have had members that have had this wiring damaged, leading to this condition. You can get a new harness for fairly cheap ($70 as I recall) if it is damaged.
Old Apr 24, 2012 | 07:46 AM
Thanks I'll have to find out where exactly it is located I'm
Not familiar with its location.
Old Apr 24, 2012 | 07:51 PM
Kota62's Avatar
Noxparadise:
Here's a pic from when I swapped the front springs
HTHs
Gary
Old Apr 25, 2012 | 07:48 AM
The front is located where the back is located correct?
Since you changed out your springs, if my suspension is squeaky especially in the back what do I need to do to fix that? Also can the back suspension mess up my alignment? I had my alignment done they couldn't do anything because they said my suspension was bad and couldn't align my rear tires.
Old Apr 25, 2012 | 08:37 AM
pab's Avatar
pab
See another thread. It sounds like you have the very common alignment problem caused by worn bushing in the rear controls arms. There has been lots of discussions about that in the last year. They're not a really big problem to fix.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Apr 25, 2012 | 09:40 AM
Cool
Thanks a lot! I'll look into it the place that did the alignment did an estimate to fix it all for like 3,500$ I thought they were nuts..
Old Apr 25, 2012 | 03:53 PM
Thermo's Avatar
Veteran: Navy
Noxparadise, you can get the lower control arms (which is what normally goes bad) for around $100 a side. To replace them, all you do is remove the wheel from the car, remove 2 bolts, the arm falls out of the car. Put the new arm in its place, reinstall the bolts, reinstall the wheel. All done. Do not forget to get the alignment redone. If you want to fix any and all possible errors, then you need to get the upper arm too. That would be another $100 an arm. So, for around $450 and say 2 hours of your time, you can fix your rear alignment issue yourself. The upper arms are just like the lowers, remove two bolts and the arm falls out of the car.
On a side note, if you do the upper arms, can I get your old ones? I am looking to come up with a way to save us some money and I am looking for a set of old arms. I will pay for the shipping, I just want the old arms.
Old Apr 26, 2012 | 07:52 AM
Ok cool
Thanks for the info, I was just wanting to get some incite on the alignment issue. I'll probably try the lower ones first and see what happens. The speed wheel sensor shouldn't be too difficult to remove and replace I've read.
Old Apr 28, 2012 | 07:04 PM
What If the plug is going into the frame of my car and I cannot unplug it??
Old Apr 29, 2012 | 06:23 AM
It's the driver side rear Speed sensor that I'm talkin about.
Aranon
Sep 3, 2015 07:56 PM
johanasu
Sep 3, 2015 12:39 PM
frankc
Sep 1, 2015 04:41 AM
lee,lee
Aug 31, 2015 04:35 PM
tberg
Aug 31, 2015 04:33 PM
