ABS light on....
Old Mar 2, 2014 | 02:58 PM
ropetec007's Avatar
Question ABS light on....
Hi All,
I drive a 2003 X type 3.0 auto AWD, starting and driving is fine with no issues, however when I switch off the car and then start again within a few hours the ABS light comes on and stays on...... This happens all the time even after a few miles trip. The red light for the brakes comes on also.
Appreciate any help!
Old Mar 2, 2014 | 03:22 PM
Five Speed's Avatar
Could be abs sensors or reluctor rings need attention, Hand brake needs adjustment , Brake pads are worn past their reccomended limit . You may also get your EML light come on as the pute detects other warning lamps are on. A proper diagnostic check ( Cheap machines wont detect brake probs ) ...should point you in the right direction.
http://www.ukpartsdirect.com/?gclid=...FYMSwwod5z0Akw
Old Mar 2, 2014 | 03:28 PM
ropetec007's Avatar
Thanks very much, I will get it looked at soon.
Old Mar 8, 2014 | 02:15 AM
ropetec007's Avatar
Question
Hi, if the reluctor rings are suspect what would I need to order to replace?
Apologies if its a daft question!
Old Mar 8, 2014 | 05:34 AM
Five Speed's Avatar
Depends on if they are front or rear rings . Rear rings are loctated on the drive shafts & front ones are located in with the front wheel bearings .. " Google " Jaguar X type Reluctor Rings ..Lots of firms who sell them , make them & fit them , should come up !!!
Old Mar 8, 2014 | 05:35 AM
Five Speed's Avatar
If its not rings , it could be sensors or sensor wiring harness /loom....
Old Mar 8, 2014 | 09:49 AM
ropetec007's Avatar
That's great, thanks for the advice.
Old Mar 8, 2014 | 02:03 PM
Dr dome's Avatar
if it is more then one sensor. it could be your abs modular. I have the same problem and changed out all the sensors. The only thing left is to change out the unit itself. I am going to try that in a few weeks when I get time.
Good Luck,
The Dr!
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
