Activating Voice Dialling
Hi all,
It's been a while since I posted here but I've got an issue I hope someone can help with.
In the past couple of weeks I have purchased a 2005 X-Type Sovereign to replace my 2001 SE that had an unfortunate MoT disaster that was no longer cost-effective to repair :-(
The Sovereign is great, but it was lacking one feature - BlueTooth.
I have purchased the later BT module and the antenna, as well as a Fibre cable and linked that in to the Fibre loop. Found the wiring loom for the BlueTooth module tucked away and basically fitted everything and, amazingly, it worked first time! All is good and I can use the screen to dial, phone contacts sync and people can hear me fine. Result!
Well, not quite. The Sovereign has Voice control and I can't get it to recognise any Voice commands for phone at all apart from the one to display the Phone screen. All other Voice commands are fine (Radio / Climate / CD Changer).
I have been into the secret menu from the screen using the Phone and Menu buttons and code 1971 and checked that the Phone module is listed as installed and this is indeed there and present.
What do I need to do to get the Voice control module to recognise the Voice dialling commands as well as the others that are already working fine?
Thanks in advance for any pointers.
Regards
TMW
Regards
TMW
Hi,
Thanks for the doc, however it doesn't help unfortunately.
If I try any of the phone commands it just says "command not recognised" on the trip display.
It's as if the voice module needs to be told it's got a Bluetooth phone to control now as well...
Regards
TMW
Regards
TMW
martin49315
May 29, 2017 04:46 PM
WinterJag
May 30, 2012 09:46 PM
