Air con problem
Old Aug 5, 2019 | 12:25 PM
William Turner's Avatar
Default Air con problem
Hi I have a 2.5 x type,with air con probs,I've had the compressor changed, the seperator and the pressure switch under the front drivers side wheel arch. Clutch cuts in and out ok Problem is it still isn't blowing cold air,just wondering if anyone has any ideas as to what could be my next step......HELP....GRRRRR silly car...
Old Aug 5, 2019 | 03:25 PM
Dell Gailey's Avatar
When you change the air exit options (floor, face, etc.) does the exiting air make the change? The other possibility is the stepper motor on the "close heat" i.e. The heater core one is stuck or broken and not bypassing the heat. It is always hot, it's supposed to be bypassed when A/C used.
the bottom stepper motor is for the blend door - that controls the temperature of the air by allowing the right amounts of cold and hot air to get what's wanted
S type, but same procedure =
https://www.jaguarforums.com/forum/s...ustment-38844/
Tink
Sep 1, 2016 01:04 AM
ohsigmachi
Mar 16, 2010 01:03 PM
biffta
Jul 1, 2009 03:51 PM
Hong
Jul 13, 2008 11:43 PM
