airbag lights
Old Nov 12, 2008 | 01:55 PM
Brutal's Avatar
Default RE: airbag lights
USUALLY A WIRING SHORT IN THE DRIVERS SEAT HARNESS, TRY TO DRIVE WITHOUT SITTING IN THE DRIVERS SEAT. MAYBE A BACK SEAT DRIVER
Old Nov 12, 2008 | 05:09 PM
racerx82's Avatar
Default RE: airbag lights (brutal)
Sounds like you got a short in the system. Have you had any electrical work done? If not, look under seats, there is a cluster of wires, maybe one got pinched when the seat was moved forward/back
Old Nov 12, 2008 | 05:57 PM
racerx82's Avatar
check all the wiring up front then, around where the headlamp is. maybe one of the impact sensor wires got pinched.
Old Nov 12, 2008 | 06:40 PM
Brutal's Avatar
EVERY JAG IVE HAD THAT KICKS THAT FUSE HAS ENDED UP BEING THE WIRING IN THE DRIVERS SEAT. MANY TIMES AT A CERTAIN POSTION, WEIGHT IN IT, OR IS A PERMANENT SHORTTO GROUND. UNBOLT THE DRIVERS SEAT, DISCONNECT THE ELECTRCAL CONNECTOR FROM THE SEAT AND SEE IF THE FUSE BLOWS AGAIN, THE LIGHT WILL STAY ON SINCE IT DOESANT SENSE THE SEAT POSITION OR AIR BAG AND PRETENSIONERS, SO DONT GO BY THE LIGHT STAYING ON
Old Nov 12, 2008 | 06:50 PM
Brutal's Avatar
THE UNFAMILIAR PERSON SHOULD JUST REMOVE ALL 4 BOLTS HOLDING THE SEAT DOWN, ALTHOUGH I CAN USUALLY DO WHAT I WANT BY UNBOLTING ONLY THE FRONT 2
Old Nov 12, 2008 | 08:16 PM
racerx82's Avatar
i don't get it.
Old Nov 12, 2008 | 09:04 PM
Brutal's Avatar
uhhh, I usually answer from memory, but before I answer erroneously, Ill have to ck
Old Nov 12, 2008 | 09:08 PM
Dennis's Avatar
ud
Maybe a lowjack module or one of those insurance black boxes that records speed before a crash..or a big brother box...
okay, maybe I'm talking out my ****
Old Nov 12, 2008 | 09:22 PM
Brutal's Avatar
no Dennis, partially right, but the big brother box is in the ecu, not under the seat
Jpav27
Jul 31, 2022 06:43 AM
XJsc-guy
Nov 23, 2015 01:56 PM
redrover41
23
Sep 25, 2015 01:33 PM
34by151
Sep 6, 2015 05:14 PM
AL NZ
Sep 4, 2015 08:39 PM
