alignment issue
Old Sep 7, 2011 | 02:07 PM
sidewalkman's Avatar
Originally Posted by dvd711
Hey Brutal have spoken to you in the past and would like to thank you for all your straight up help.
My issue now is excessive inside tire wear on the 2 front tires.
Car info = 04 jag xtype 2.5 90k mi //
tires = 225/30zr/20 20" wheels.
Alignment issue?
Negative camber?
Toe in/out?
Worn control arm bushings?
Is the dealer the only option for the alignment?
What is the approx. cost of just the alignment?
Thanks in advance...David
See my above post. Rear alignment affects the front as well. Like I said, it wore the inside of my right front down to the cords to the point it was leaking.
Old Sep 7, 2011 | 02:35 PM
Brutal's Avatar
hey brutal have spoken to you in the past and would like to thank you for all your straight up help.
Alignment issue?
Negative camber?
Toe in/out?
What is the approx. Cost of just the alignment?
Thanks in advance...david
d all the above(possibly) except too much toe toe in. With 20's it can increase the leverage on the suspension and cause more toe out while driving than when sitting on a rack. I had an acura yrsa ago that did that until i aligned it to the point the toe in was out of spec and into the red. But it never wore tires out again
Old Sep 7, 2011 | 08:41 PM
dvd711's Avatar
Hey Brutal...thanks for the info.
Could you please take a look at the attached photo of my tire??
thanks...d
Old Sep 7, 2011 | 09:06 PM
Brutal's Avatar
well personally, i would increase toe in and check deflection while on the alignment rack to see how much the suspension moves (toes out). too many tech would never think about deviating from factory specs. They expect the machine to be the end all. To me the tires are the end all. Theyre telling the story and you have to use experiance and the before alignment settings. tire wear and make a determination on the BEST course of action. An alignment is a compromise. there are trade offs. Most want a straight driving non tire wearing alignment. Then there are those that want the most grip in high speed cornering. Some want faster quicker turn in, or high speed straight line stabilty(drag racing) they all have trade offs. But for most all communters and striaght car that doesnt wear tires( I llaugh when people say" I dont need an alignment, my car goes perfectly straight" well that may be, but your tires are showing cords inside
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
James007
Oct 3, 2015 03:29 PM
Darrenmb
Sep 8, 2015 06:12 PM
James007
Sep 6, 2015 06:47 PM
