Automatic Trunk (boot) Opening!
Old May 20, 2018 | 05:56 PM
wa3ra's Avatar
Default Automatic Trunk (boot) Opening!
Quick mod on the trunk over the weekend; all that is necessary is a new set of struts, and in my case a new pair of actuators sine both of mine were MIA.
Strut specs: 300mm length, 10mm ball ends, 600N force. They were easiest to source from the UK. (https://www.ebay.com/itm/2X-UNIVERSA...72.m2749.l2649)
I picked the actuators up from Engel.
video here:
Old May 20, 2018 | 06:48 PM
iownme's Avatar
video here:https://youtu.be/A12Kss0VuHA
i like that mod!
is the trunk any more difficult to close?
Old May 20, 2018 | 07:28 PM
wa3ra's Avatar
Yes, but not too much so. The factory struts are 450N, the replacements 600 newtons, so it takes just a little more to overcome them.
Once they start moving, no issue.
Old May 20, 2018 | 07:57 PM
AndrewG's Avatar
This may be a dumb question but could there be any concern of maybe this being to much force and affecting the hinges or something else? It seemed to bounce a bit once it got all the way to the end.
Old May 20, 2018 | 08:35 PM
wa3ra's Avatar
It bounced the same amount with the 450s.
The 800s that some of the first guys to do this seem to be a bit much, but nothing is overextending. The strut itself is what is bouncing, by the way, not the hinge.
You might have to pad the actuator pin to raise the trunk enough to actually open, I used a 2mm rubber pad (1/10th of an inch); anything too high can push up on the edge of the trunk lid, but that takes more than 1/3 inch. Many people seem to use 1/4" washers glued to the pin to provide the extra lift.
Old May 20, 2018 | 09:34 PM
AndrewG's Avatar
When you say actuator pin do you mean that metal pin that sticks out where the latch itself grabs? Or something else?
Old May 21, 2018 | 12:38 AM
wa3ra's Avatar
The spring-loaded actuator center post strikes a small metal protrusion on the underside of the trunk lid when closed.
Making either of them the tiniest little bit longer increases the spring preload that forces the trunk lid up when the release button is pushed.
Old May 21, 2018 | 04:58 PM
Dell Gailey's Avatar
What is "Engel"?
Old May 21, 2018 | 05:02 PM
My trunk has never opened. It unlocks, raise it and it stays up fine. Never "falls down" or droops, so compression to stay open is fine. When I first bought it, I did a search here and nearly everyone posting said that was normal (not springing all the way open). BUT, I would like it too when hands are full and loading trunk.
Were the struts reasonable? Cause around here the hood struts etc. for other cars cost a bundle.
Old May 21, 2018 | 05:44 PM
wa3ra's Avatar
Engel Imports is Terry's Jaguar Parts.
The struts ran me around 19 pounds including shipping, just under $25 delivered, Paypal handles the currency exchange.
Old May 21, 2018 | 09:02 PM
Hmmmm......
Old May 22, 2018 | 02:11 AM
wa3ra's Avatar
The actuators came from Terry's; the struts came from the link in the original post (eBay UK).
Norm 427
Jan 20, 2013 01:39 PM
guru
Mar 14, 2009 03:22 PM
JimC64
Aug 17, 2007 02:42 PM
