AWD in reverse?
Old Jul 19, 2012 | 03:02 PM
Bodach's Avatar
Default AWD in reverse?
I have been told by an ex-X-Type owner that the AWD only works going forward. Since it has not snowed here last winter I had no chance to test the therory.
I'm just wondering I don't know that this means anything as long as the car goes forward I'm good
Old Jul 19, 2012 | 03:12 PM
Cambo's Avatar
No...the AWD definitely works in both directions...maybe that former owner had a post 2004 model without DSC & didn't know the handbrake trick...
Old Jul 20, 2012 | 08:42 AM
pab's Avatar
pab
Can you say a little more about that trick?
If the wheels are spinning when do you pull up on the E-Brake, while the
wheels are spinning or before stepping on the gas?
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Jul 20, 2012 | 10:59 AM
AML's Avatar
AML
What year is your Jag?
After 2004 they switched to an open differential setup that was pretty much useless. It wouldn't transfer power to the front wheels unless you pulled the ebrake creating resistance in the rear and forcing the power to the front.
Before 2004 there was a much better performing (althought reliability was questionable) viscous coupling. Power would transfer between axles naturally in this setup.
Old Jul 20, 2012 | 11:10 AM
jagger's Avatar
Are there drawings or pictures of the internals of these transfer cases.
I would like to know exactly how they work.
Thanks,
Pete.
Old Jul 23, 2012 | 06:50 AM
Bodach's Avatar
OK thanks Guys that clears it up er sort of.........
My X-Type is a 2006 so it suffers from the new transfer case. I'm happy to know there is a trick if I ever park up to a snowy cliff there is a way out.
Paora
Feb 4, 2021 12:36 AM
Pringleblue
Jan 12, 2021 11:42 PM
Johnken
Oct 2, 2015 10:12 AM
jjmiah217
Sep 28, 2015 09:09 AM
