Bank 2 sensor 1 02 sensor removal
Old Jul 13, 2014 | 08:53 AM
ghoward986's Avatar
Default Bank 2 sensor 1 02 sensor removal
HelloI have been trying to replace the Bank 2 sensor 1 02 sensor on our X-type. I have looked through the forums but cannot find out what is the best way to remove the sensor.
The sensor is behind the radiator and is difficult to access. I have removed the air box but cannot seem to get my o2 sensor wench around it. I have read that you need to remove the plastic coolant line but the bolts for this are at an angle and pointing down.
What is the best way to access this sensor and replace it with a new one? Is there a special tool that I need to make this easier?
Thank you in advance.
Gary
Old Jul 13, 2014 | 07:11 PM
earthdogjim's Avatar
I rented the o2 sensor wrenches from Autozone and had the girlfriend stick her smaller hand down in there to get it out and screw in the new one. (I handed her a cold Guinness when she was done)
I had to use the silver 7/8 socket that has a cut in it for the wires to get mine out.
Old Jul 13, 2014 | 07:52 PM
ghoward986's Avatar
So did you have to remove any parts to reach it or where you just able to do this without removing any parts?
Thank you
Gary
Old Jul 14, 2014 | 07:07 AM
Just had to remove the cover that says Jaguar and the air filter box
Old Jul 16, 2014 | 07:01 PM
ltmax's Avatar
I cut the wires off my old sensor and used the closed end side of a regular wrench, worked like a charm.
Old Jul 19, 2014 | 04:02 PM
ghoward986's Avatar
How did you reach it. I am having a problem getting my o2 tool onto the sensor. I have read you need to remove the coolant pipe under the airbox but was trying to avoid this.
Old Jul 19, 2014 | 04:18 PM
johnf223's Avatar
I did this a few months back. I ultimately removed the plastic coolant hose, which, like you, I was trying to avoid. It was easier with the plastic hose removed. Removing the air box and intake horn also helps for access. I have the open type of O2 sensor socket which fit after a little finesse, including widening the hole on the manifold cover slightly. Make sure you have a good fit with the socket, as it takes a bit of force to break the threads. Good luck!
john
Old Jul 19, 2014 | 05:37 PM
ghoward986's Avatar
john
How do you remove the plastic coolant hose?
Thank you
Gary
Old Jul 19, 2014 | 06:24 PM
johnf223's Avatar
Thank you
Gary
If I recall there are squeeze type hose clamps on both ends and a screw that holds it in place. Will need to drain out some coolant first or catch it when you disconnect the pipe
Jandreu
Jan 23, 2017 10:58 AM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
Sep 6, 2015 06:51 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
