Battery Replaced..now some quirks
Old May 21, 2010 | 02:07 PM
Strafe's Avatar
Default Battery Replaced..now some quirks
So I just replaced my battery. The oem held up for 6 years. Anyhow, now the windows won't "auto" roll up (down works fine) and the AC isnt blowing cold.
Anyone have any idea what's going on here?
Old May 21, 2010 | 02:15 PM
The Chris X's Avatar
Sometimes you have to mess with the auto features a bit. With the windows up, hold the button down about 5 seconds after the window comes the whole way down. Then pull it up and hold it about 5 seconds after it goes all the way up. Do it for each window.
AC not blowing cold should be completely unrelated. The HVAC will revert back to default settings. Is your AC button lit up (sorry, but had to ask).
Old May 21, 2010 | 02:18 PM
CarMan007's Avatar
If what Strafe said doesn't help just give it about a week and it will start auto rolling up again.
Old May 21, 2010 | 02:19 PM
CarMan007's Avatar
If what Chris said doesn't help just give it about a week and it will start auto rolling up again.
Old May 21, 2010 | 02:25 PM
Strafe's Avatar
I'll give that window thing a shot.
The A/C light is definitely on. I've tried turning it on and off multiple times to see if it will reset itself. No luck so far.
Thanks for the help fellas!
Old May 21, 2010 | 09:05 PM
Strafe's Avatar
That worked for the windows! Thanks!
Still no luck with the A/C blowing cold.
Old May 21, 2010 | 09:13 PM
jn_lego's Avatar
after disconnecting my battery my ac light is one and the same with the auto light.. i can't turn one off without the other. drives me nuts but i wont get pissy until winter.
Old May 22, 2010 | 07:41 AM
jn it is probably due to the temp setting you have in auto mode. IF it needs to cool or defrost /demist then the AC will always be on.
I hate the auto mode, mostly just manually adjust the settings to keep the AC off.
So Strafe the AC was working just fine prior to changing the battery? And you have put the HVAC on the LO setting? Try putting it on LO and manually selecting AC and see what happens if you haven't already.
Can you see/hear the AC compressor clutch kick on?
Old Aug 15, 2010 | 11:35 AM
2004xtype3.0's Avatar
So I removed and replaced my battery in an attempt to get the voice commands on my factory navigation to work, It didn't help, however, it did turn the temperature controls and readout to Celsius instead of Fahrenheit and I can not for the life in me figure out how to change it back to Fahrenheit. Also.... The oddest thing, when I took the battery out, the radio preset stations did not reset.... and I had the battery removed for over 15 mins?!?
Old Aug 15, 2010 | 04:22 PM
Thermo's Avatar
Veteran: Navy
2004, look under the settings portion of the radio. There is a feature in there that allows you to select either F or C. It is under the "User Settings" or another screen where you can set up the radio for how you want it to respond.
Old Aug 16, 2010 | 09:47 AM
Strafe's Avatar
My A/C just started to "magically" work again.
I reckon it's one of those electrical Jaguar mysteries that were blessed with.
jluckcuck
Nov 6, 2015 07:49 AM
Msteiner
Oct 1, 2015 01:18 AM
Swagguar
Sep 30, 2015 01:34 PM
oldjaglover
Sep 29, 2015 03:27 PM
