Before I buy another Jaguar/2002 X-Type Qs
Old Nov 25, 2010 | 04:19 PM
c_corie's Avatar
Default Before I buy another Jaguar/2002 X-Type Qs
So it's a 2002 3.0 Auto X-Type with 40k on it. Dealer checked and said it was not affected by the trans recall. Only issue I can tell is it has the brake interlock clicking ALL the time. Very annoying, is it easy to fix? Anything else I should be checking for, any issues that are very easy to see/hear? Thanks!
Old Nov 25, 2010 | 07:12 PM
ghettomike's Avatar
wait...what transmission recall?????????
what did i miss? the tranny in it blew and just had it rebuilt!! i want a refund and a new fixed tranny!!
Old Nov 25, 2010 | 07:20 PM
Hey there, please check the X type quick FAQ link thread.....all the info you need, just read till your hearts content.
You might consider looking at an 03 - 04 if possible as some of the minor issues / problems that the early models did sometimes suffewr from were usually resolved by then
Old Nov 25, 2010 | 07:51 PM
mohrd's Avatar
GMike, there was no actual autobox "recall", it was a "campaign". The only recall I can remember was on rear signal lights. The Customer Campaign on the early NA X-types had to do with poor original Jatco auto trannys on some. If a customer complained of difficulties, some of the trannys were replaced. In early warranty work on '02s, Techs were looking for bad trannys. The campaign closed in 2009 but you may still have a chance if you had an original bad one. Here's how to tell by serial #.
Transmission Serial Number Check Procedure
1. Open hood and place covers over fenders.
2. Check the transmission serial number to verify the status of the transmission.
3. The transmission serial number is located on the top of the transmission and can be viewed when looking down between the brake reservoir and the battery cover
If the transmission serial number starts with 11*****, 12***** or 13***** on 2.5L and 3.0L vehicles, or is between 1908384 to 1X09438 on 3.0L vehicles, or 1908190 to 1X08740 on 2.5L vehicles, the transmission MUST be replaced unless the serial number has a suffix "A" or "R" stamped behind the number.
Old Nov 25, 2010 | 08:47 PM
j_bond's Avatar
Agreed. Stay away from a 2002. Preferably, 2004+
I had an inexorable amount of problems with my 2002. The design of the 50/50 split of power creates a weakness in all of the earlier 3.0 models, and will inevitably lead to failures in the transmission components down the road. I realize this is a touchy subject which many will argue such a notion, but my 2002 saw transmission failure TWICE, light failures, several window failures, moonroof failure, alternator failure TWICE, battery failure, fuel pump failure, and lock/unlock mechanism failure. One may find themself quite irritate by these quips unless technically savvy and able to ameliorate these problems themselves.
Old Nov 25, 2010 | 09:49 PM
c_corie's Avatar
Ohhhhhhh. Hm.....so maybe this is not the deal that it seems. The car would be about 11500 after everything, and its in near new condition. But now I'm not so sure.
Old Nov 26, 2010 | 08:36 AM
Alfadude's Avatar
Boy, that seems like a high price for a 2002, even with the lower miles. I know used car prices have gone up quite a bit in the last couple years, but even so, that seems high for a 2002 X. I bet you could get a 2004-2005 for that price with some patience even if it might have some more miles.
Old Nov 26, 2010 | 08:48 AM
Jaguarnewbie2011's Avatar
If your driving in a cold climate check the recirculation botton to make sure it works, otherwise the car will fog up in the winter. Mine has that problem, and I am trying to get it resolved with the dealer.
Old Nov 26, 2010 | 04:45 PM
TheSeeker's Avatar
That's just WAY too much for a 2002!
Old Nov 26, 2010 | 04:58 PM
ghettomike's Avatar
YA $11,500 is overpriced but that is really low km...is that km or miles??.
im going to go take a look at a 04 for $8000 with i think 150km or so on it. its black on black 3.0L with the chrome trim on the bumpers and chrome grill..i dont know what the trim package is called for that.. its on the lower end of the x's in my area but for 10 you can get a 04 thats probably slightly lower km than the one im lookin at..i saw some at 11-12 with 60km on it. im just lookin for a winter car tho to replace my gas guzzler truck that can still handle itself in snow...awd is a must.
Old Nov 26, 2010 | 05:06 PM
TheSeeker's Avatar
I would suggest going to Kelly Blue Book and looking up the value of that car in your own zip or postal code. I suppose we also have to be careful talking mileage and prices as this is an International forum so without specifying USD, CAN, km, and miles one might get confused.
Old Nov 26, 2010 | 06:58 PM
c_corie's Avatar
That's after taxes/moving plates/fees and what not. Its like.....500-600 over book value at the original 10500 price, but it realllly is in good shape. also it has 40100 miles on it. and has a clean one owner car fax. which really does seem to help its value, at least to me.
Old Nov 26, 2010 | 07:01 PM
c_corie's Avatar
Also 3-4 year s ago I bought a 1998 XJ8 VDP for 13500 because it only had 33000 miles on it. im not apposed to spending a little more then a car is "worth" if its a one owner, with lower millage in almost new condition.
also the 98VDP was recently totaled (not my fault), and i'd really only be taking out a 3500 loan so its not THAT bad.
Old Nov 26, 2010 | 08:43 PM
mohrd's Avatar
I would agree that's too much money c_corie. Buying it from a Jag dealership or another dealer? The car is going on 9 years old from production date and, even with the low miles that kind of dough is a stretch. Should include a 3 year/36,000 mile warranty at that price.
Old Nov 26, 2010 | 09:51 PM
j_bond's Avatar
I assure you.... the x-type does not get that fantastic of gas mileage either if you are merely using it instead of your truck for the "gas mileage-benefit..."
Old Nov 26, 2010 | 10:31 PM
exexpat's Avatar
My 2004 was $10,500 with 45k on it a year ago. The dealer (BMW of Seattle) was trying to get $15,9 for it, but I kept looking and a month later knew they had to make a decision to wholesale it or make almost nothing on it - luckily they went for the latter option. It's been a good car over the last year - knock on wood. Anyway, a 2002 shouldn't fetch over about $9k even with absurdly low miles. Subtract 2-3k if it is an east coast car (rust).
Old Nov 26, 2010 | 10:33 PM
Disco stu55's Avatar
What did i miss? The tranny in it blew and just had it rebuilt!! I want a refund and a new fixed tranny!!
me toooo i want my 4500 back
Old Nov 27, 2010 | 09:23 AM
Alfadude's Avatar
I agree about the warranty, especially if you would buy it from a Jaguar dealer and would get the factory Select warranty. That deinitely would have some value, but still not enough to justify that price. Something else to consider is what trim levels does it have? If it's more of a base model (no nav., heated seats, premium stereo, Sport model, etc.) that would make that price seem even higher. Our cars are not the easiest for a dealer to sell, which is a definite plus when looking to buy. Make sure you do your research BEFORE you buy so you know differences/problem areas between the model years and the different option packages that were offered so you can make as an educated decision as you can. Don't think that just because you are getting a low mile Jag for $11K that automatically makes it a good deal. For what you can get for the money I think the cars CAN be a steal. Just make sure you know what you are looking at. I have a 2005 and have owned it for over two years and 40K miles and it's been fantastic. Good luck in your search.
Old Nov 27, 2010 | 11:51 AM
dennis black's Avatar
stick with the 02-03 ive torn down transfer cases and trannys with my cousin at the jag dealer ...the most reliable and best in the snow are the 02-03...but you must bullet proof it a lot of jag owners neglet these two items ....on the 02-03 awd system you can put a snow plow on the front of your bumper and plow your whole neighborhood lol
this is just my opinion if it was me buying another x
when buying one ,first priorty is changing drivetrain fluids
Old Nov 27, 2010 | 05:07 PM
The Chris X's Avatar
I prefer the feel of the earlier AWD set up as well, but I was quite thorough in my maintenance and still had problems. I loved the car, but if I was buying now I'd opt for 2004 and up most likely. Mostly just for the less exposure to the elements. If that car you are looking at has spent its live in CT, I'd guess you have some sill rust even with those low miles.
Maybe keep shopping, you might find a newer model for around the same money or even less. Not much of a difference between 40k mi and 60k miles...I'll take less years.
OR if you hack them down to $8 or $9k then maybe pull the trigger.
