Blank Navigation screen
Old Apr 11, 2015 | 05:02 AM
  #381
arturoart25's Avatar
Hi, I need help with a 2003 Jaguar s-type Denso navi. I messed up with the update and have a blank(black) screen. I need a software DVD to restore it. Thanks a lot. Please send it to arturo.art25@gmail.com Highly appreciate it.
Old Apr 11, 2015 | 12:48 PM
  #382
vladislavsm's Avatar
I fry my nav system, I changed it modul from one other Jaguar XJ and I got screen to work again. Cd and did discs is not help to restore the old system to work. Sorry for my English
Old May 2, 2015 | 07:53 AM
  #383
Arishe's Avatar
Default Help pls
My jaguar s type navigation screen went blank nd I discovered dvd player missing in the luggage compartment, can this make the screen go blank.
Old May 2, 2015 | 08:25 PM
  #384
Paulc732's Avatar
Unfortunately yes, the dvd player has hardware that controls the screen and the climate control. not to mention all the software.
check Ebay for a replacement dvd player and you will also need a navigation disc.
Sorry for the bad news.
was the car broken into? you may be able to claim on your insurance.
Old May 3, 2015 | 05:57 PM
  #385
ray06's Avatar
May I have that software as well? If i gave you my email address? My Jag is giving me the same issues..
Old May 4, 2015 | 05:34 AM
  #386
Paulc732's Avatar
ray,
PM me I am in Lititz I can take a look for you.
Old May 5, 2015 | 06:32 PM
  #387
05jagstype's Avatar
Default blank screen
Originally Posted by solidx
Sorry guys I was off the forum for a long time and just check this threat. here is the file you will need to get rid of the blank screen.
1. Burn in a Dual layer DVD using the slowest speed.
2. Turn on car, insert disk.
3. Turn off car.
4. Turn on car and wait for it to start reading. It should come up automatically.
Latest LOADING.KWI
still have a file to get rid of blank screen?? please help this heat it burning my baby up in the car
kashandcomputers@gmail.com
Old May 6, 2015 | 05:45 AM
  #388
Paulc732's Avatar
Here is a link to the thread with the file you need.
PM me if the link to download is not working.
https://www.jaguarforums.com/forum/x...d-link-138788/
Old May 12, 2015 | 03:06 PM
  #389
sexee10's Avatar
Hiya Im having exactly the same problem, but its only occurred since the battery died. The code is 50 51 C1, all the fuses & connections are fine, the cd would'nt eject initially but managed to eject it now. Can someone please HELP!!! Thankyou,
Old May 12, 2015 | 04:23 PM
  #390
Paulc732's Avatar
what year navigation disc do you have?
Make sure your battery has a full charge and have it Load tested our cars are extremely sensitive to a bad battery.
have it load tested and if its below 85% you will need a new one.
what was the problem with removing the disc?
does the disc spin up when the keys are in the ignition and turned so the dash lights come on?
if your battery is good try the Loading.kwi file fix.
the 50-51 error is loss of communication check the connections in the back of the unit then there is one under the back seat and also one by the pasanger side footwell (uk car) its green. then finally the screen.
Old May 12, 2015 | 06:15 PM
  #391
sexee10's Avatar
Thankyou. Disc is 2003. Yes checked the connectors but was unable to get to the one under back seat, will check that though. Wasnt able to unclip the green one however will try again. The disc wouldnt eject but took the surround off and pressed the release mechanism. Your help is much appreciated
Old May 13, 2015 | 06:06 AM
  #392
Paulc732's Avatar
does the disc spin up when you start the car?
do you have power to the DVD unit in the trunk?
do you have anything else installed in the trunk amp, phone module etc....
do they have power.
how was you battery?
Old May 13, 2015 | 08:28 AM
  #393
sexee10's Avatar
No the unit in the boot isnt doing anything. Yes there;s power going to it (it was working perfectly before the battery died) No nothing else in the boot. Will be checking battery with tester early eve, will let you know. Can get the inspection screen up (press nav up nav up nav up audio audio audio)
Old May 15, 2015 | 09:53 AM
  #394
sexee10's Avatar
Hiya yes checked battery it is good, all the connectors are fine.
Old May 15, 2015 | 10:01 AM
  #395
Paulc732's Avatar
Sounds to me like the DVD unit in the boot has failed.
perhaps if you know someone who has a working unit you could borrow it and see before getting a new one.
Old May 15, 2015 | 10:15 AM
  #396
sexee10's Avatar
Thankyou. Your help has been much appreciated.
Old May 20, 2015 | 11:03 AM
  #397
Cortland's Avatar
Default Similar Issue with Touchscreen
Hello All,
I am having a similar problem occur in my 2008 XK. The touchscreen has worked fine all this time, but on Monday it started looking like the below picture. Has anyone seen this or know how to get it working properly. Driving without any audio, navigation, or temperature control is tuff.
Thank you in advance.
Old Jun 7, 2015 | 06:38 AM
  #398
Richard williams's Avatar
Hi would you please be kind to help me?
Old Jun 7, 2015 | 06:43 AM
  #399
Default Help jag blank screen
Originally Posted by 200Volts
69XKE, check your private messages.
Got blank screen when i pressed phone+menu
Please help. Tnx
dictionary772@gmail.com
Old Jun 7, 2015 | 06:46 AM
  #400
Cambo's Avatar
Blank screen and showing 50-51
Here is a link to my dropbox for the 2010 loading.kwi file
https://www.dropbox.com/s/eln51a0gy9...ADING.KWI?dl=0
download,
burn with any software to a blank DVD and finalize.
Eject your nav disc and insert the loading.kwi disc
remove your keys for 30 seconds
start your car
everything should be ok after about 5-15 mins
good luck!!
Everything you need is there.
