Blank Navigation screen
I'm with you fellas. I'm pinging here in hopes that the software fix is still floating out there.
I have removed my black box from the car (2R83 10E887 AB), opened the unit, and found nothing obviously amiss. I'd really like to know if this thing is "bad" or not....if there is a potential software upgrade to address the black screen 50/51, defrost default, I would greatly appreciate it.
Help?
Help?
Just to let you know that mine is now fixed. Fortunately it was not a fault with the DVD player but I had no choice but to let Jaguar do the necessary software upgrade for around Ģ110 plus VAT, as no one came forward with free software.
Chris
Chris
My experience was the same as Essexes.
Software update for the DVD/Navi operating system at the dealer cost me $53 ( .5 hrs)- which I plan to ask some questions on, as I feel this should've been done during the diagnostic hour I was previously charged, as the TSB's indicate updating the software is the first thing to do, before continuing diagnostics....
I did not get a hardcopy of the system update. Sorry fellas.
Kind Regards.
Kind Regards.
Hi at all,
I've same problem that happenede to solidx and others users with my navigation system (x-type 2005):
After downloading new map 2010/2011 (aftermarket bought)
, done with ignition on and nav on (previous map 2003 dvd was extracted without turn off ignition and nav system) the screen began black and climate, telephone, audio cd doesn't work in the same time.
After hours of search in internet, I went in this thread and red the same problems happened to others users.
I need the sftware setup, because the system doesn't work nothing after hard reset (pushing simultaneously telephone and menu buttons) and removing battery load for a few minutes...
Thank anybody could help me
My email is:
pioxlll@hotmail.com
My email is:
pioxlll@hotmail.com
I Am a new member and have the same issues as most in this thread,nav screen blank,hvac only blows out defrost.buttons arround screen do not light up and codes 50 & 51 found that another 03 x type owner was able to reboot thiers via a file durned to dvd is this file still out there and could you send it to me to see if it reboots mine
This file in less 6 MB and isn't loading.kwi!
post me for link
I FOUND ON EBAY A SELLER THAT POSTED ME A SEQUENCE TO REEBOT THE GPS DENSO SYSTEM!!!
I't is in Italian but is very simply procedure!!!
http://recensioni.ebay.it/Jaguar-X-T...00000020069003
Factory Jag/Solidx - guys if you could help me out with a question about the correct sequence. I found maps 2010 ~6GB however not sure if I need the SW update before the NavTeq Maps update? Please confirm and if I need the SW my mail is filip.tsachev@gmail.com.
Interesting to know what is this software update part number if any also what would be the correct Maps DVD latest part number for 2002 X type?
I found this id for 2006 maps which are somewhat confirmed to work for my unit:
Map Yr Jag P/N Denso P/N Disk(s) Disk Artwork
05/06 1X43 10E898 AH 464210-5480 1xDVD New Style
also this id for 2010 maps:
Jaguar nav 2009-2010 denso 464110-7440
Not sure if any of those is suitable for my car.
Local dealer refused to provide SW update as they do not know about it.... also they didn't have the new maps
Any idea where to check part numbers in official portal?
Think I found the missing link will test and revert
http://gpsunderground.com/forum/jaguar/213-[rs]-jaguar-xj-s-type-y-type-europa-europe-ost-west-2010-a.html
Recall - 04V487000
Open [+]
Close [X]
Make: JAGUAR
Model: X-TYPE
Model Year: 2003
Manufacturer: JAGUAR CARS LTD
Mfr's Report Date: 20041007
NHTSA CAMPAIGN ID Number: 04V487000
NHTSA Action Number: N/A
Potential Number of Units Affected: 3856
Component
PARKING BRAKE
Summary
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH LHD MANUAL TRANSMISSIONS, THE HAND BRAKE, WHICH APPLIES THE PARKING BRAKE, MAY NOT APPLY SUFFICIENT PRESSURE TO THE BRAKE PADS TO PREVENT THE VEHICLE FROM MOVING IF THE MANUAL TRANSMISSION WAS LEFT IN THE NEUTRAL POSITION. THE AUTOMATIC ADJUSTER WITHIN THE HAND BRAKE MAY NOT WORK PROPERLY CAUSING THE HAND BRAKE LEVER TO TRAVEL OUTSIDE THE RECOMMENDED RANGE.
Consequence
IF THE VEHICLE TRAVELS OUTSIDE THE RECOMMENDED RANGE, THE VEHICLE MAY ROLL AWAY AND A CRASH MAY OCCUR.
Remedy
DEALERS WILL REPLACE THE EXISTING AUTOMATIC ADJUSTMENT HAND BRAKE LEVER SYSTEM ON THE AFFECTED VEHICLES WITH A MANUAL HAND BRAKE LEVER SYSTEM. THE RECALL BEGAN ON JANUARY 14, 2005. OWNERS SHOULD CONTACT JAGUAR AT 1-800-452-4827.
Notes
JAGUAR RECALL NO. R957.CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Recall - 03V011000
Open [+]
Close [X]
Make: JAGUAR
Model: X-TYPE
Model Year: 2003
Mfr's Report Date: 20030116
NHTSA CAMPAIGN ID Number: 03V011000
Potential Number of Units Affected: 49174
Component
EXTERIOR LIGHTING:TURN SIGNAL
Summary
ON CERTAIN PASSENGER SEDANS, THE POWER CIRCUIT WHICH FEEDS THE DIRECTION INDICATOR SYSTEM COULD FAIL. THIS COULD RESULT IN THE DRIVER BEING UNAWARE THAT THE EXTERNAL TURNING INDICATORS ARE NOT OPERATING BECAUSE THE INTERNAL "TELL-TAIL" LIGHT ON THE DRIVER'S INSTRUMENT PANEL CONTINUES TO WORK NORMALLY.
Consequence
THE LOSS OF REAR TURN SIGNALS COULD FAIL TO WARN A FOLLOWING DRIVER THAT THE VEHICLE IS TURNING AND COULD RESULT IN A CRASH.
Remedy
DEALERS WILL REPLACE THE GENERAL ELECTRIC MODULE. OWNER NOTIFICATION BEGAN APRIL 1, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT JAGUAR AT 1-201-818-8500.
Notes
JAGUAR RECALL NO. R935. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Already a Rewards member,
but first time to the site?
New to the Rewards Program
and want to find out what's in it for
you and your car?
Open [+]
Close [X]
Make: JAGUAR
Model: X-TYPE
Model Year: 2003
Component
PARKING BRAKE
Summary
Consequence
Remedy
Notes
Recall - 03V011000Open [+]
Close [X]
Make: JAGUAR
Model: X-TYPE
Model Year: 2003
Component
Summary
Consequence
Remedy
Notes
you and your car?
I have the same problem with my 2001 X-type 2.5 V6. I put an update DVD in the unit and the system crashed. Now nothing works anymore. In Holland it is very hard to get the information. Most dealer donīt even know it excists!
If someone of you can mail me the software I will be very grateful. My emailadres is buijs.keesadgmail.com (change ad in @! (to avoid spam)).
Thanks a lot!
Kees
Thanks a lot!
Kees
One of the main dealers in Holland could reinstall the software, so everything is working again
Just in time because the weather gets warmer and it was warm in the car with the heater on full blast!
