Brakes lock after about a kilometer run
Old Mar 10, 2017 | 09:52 PM
edapol2007's Avatar
Default Brakes lock after about a kilometer run
Replaced the rear brake pads and calipers, when tested the rear wheels lock so I bleed fluid and locking released. Run again for a kilometer then rear wheels lock again. Please help. Thanks.
__________________
Jaguar 2006 X-type 3.0 AWD (added by GGG)
Old Mar 10, 2017 | 10:29 PM
Doug's Avatar
What kind of car?
Old Mar 10, 2017 | 11:35 PM
edapol2007's Avatar
Hi Doug, thanks and apologies for not including as much info as possible. Its a Jaguar 2006 X-type 3.0 AWD, automatic tranny.
Old Mar 13, 2017 | 09:01 PM
edapol2007's Avatar
Default Four wheels sticking, X type 2006 Jaguar
Followup to my previous post, I found out that all 4 wheels are sticking. I bleed brake fluid from all 4 wheels and it was okay for few kilometers then back again, all 4 wheels are sticking. Can anyone please help?
Old Mar 16, 2017 | 07:06 AM
Fulton's Avatar
You will get more answers if you post under the specific model rather than the regional section. The X-Type (x400) section under Jaguar Models (modern) will most likely get you an answer. Good Luck
Old Mar 16, 2017 | 08:05 AM
Welcome to the forum edapol2007,
I've moved your question from Canada Region to X-Type forum. The model forums are the place to post technical questions. Members here with the same model will be able to help.
Old Mar 17, 2017 | 02:23 PM
Larry-Cleveland's Avatar
I had a similar problem with the linkage going to the master cylinder not coming all the way back out after it got hot.
You can test this by getting them to lock up, jack the car up, and make sure they are still locked, then loosen the bolts that hold the master cylinder to the booster. If that unlocks them you have found the problem area.
Old Mar 17, 2017 | 07:38 PM
edapol2007's Avatar
Default Thanks Graham. Much appreciated.
Old Mar 17, 2017 | 08:28 PM
edapol2007's Avatar
Thanks Graham, much appreciated.
Old Mar 17, 2017 | 08:32 PM
edapol2007's Avatar
I will try this Larry - I've re-bleed the brake system and still once it gets hot (running about 10 km with lots of braking) the brakes lock again (all 4 of them).
Old Mar 17, 2017 | 11:21 PM
edapol2007's Avatar
Hi Larry, what could i possibly do if the linkage does not go back? Thanks.
Old Mar 18, 2017 | 10:40 AM
edapol2007's Avatar
Larry, I loosened the 2 nuts connecting the master cylinder to the brake booster and heard an air leaking then brakes are free again. Tried driving but then back to the wheels sticking/locking again. I would like to check the vacuum hose from booster to manifold but how to remove that I don't know. Or can anyone suggest of what should I do? Thanks friends...
Old Mar 18, 2017 | 05:29 PM
To check the hoses you spray some WD-40 type spray on and around the hoses as the car is running. If you hear a change in the motor RPM you have found a problem.
I would now look at the linkage under the dash for any binding, extra play, or rubbing on things. The pedal may be coming all the way up but not the linkage.
If it is possible to loosen or remove the master cyclinder to see how the linkage looks and feels.
Old Mar 18, 2017 | 08:19 PM
edapol2007's Avatar
Hi Larry-Cleveland, I was able to check the vacuum hose and it's working okay. I checked under the dashboard and nothing that is binding or restraining the rod to retract. But loosening the 2 nuts release the pressure and I can move again...I'm too puzzled now but thank you for your help. I wish that this issue be solved. Thanks again.
edapol2007
Old Mar 23, 2017 | 02:33 PM
Peggyford's Avatar
Hello, I have the same problem, and wondered if you have solved it, and if so how. Thanks rob
Old Mar 23, 2017 | 06:48 PM
edapol2007's Avatar
Hi Rob,
Tried everything we know, even employed the help of 2 experienced mechanics but no success. Their analyses points to replacing the Master Cylindet. I am awaiting the master cylinder I ordered last week. Will update this forum once the issue is solved.
Old Mar 24, 2017 | 12:43 AM
Peggyford's Avatar
Thanks, I have cleaned all calipers and replaced one, replaced servo, master cylinder and abs module (second hand) and still drag when engine running, unlucky if these had same problem. If I take the vacuum hose out they free. The only thing I can think of now is to adjust the length of the push rod in the booster, have you tried that.
Old Mar 24, 2017 | 04:46 PM
edapol2007's Avatar
I have not tried adjusting the rod inside the booster. What I noticed was when its locked, I loosened the 2 nuts holding the master to the booster and its free again. Then test drive, and once I travel about 10 km with lots of braking, then all 4 wheels lock again. I'm still not 100% agreeing with my 2 mechanics that its the master that's causing the issue but I bought online anyway. I will see once the new master is installed what it does, then will update you.
Old Apr 1, 2017 | 05:47 PM
Ok guys after reading that the brakes released when the vacuum was removed is a good clue!
The booster has a rubber diaphragm in the center that attaches to the rod going to the master cylinder. When you start the motor and create vacuum it is equal on both sides of the diaphragm. When you push the brake peddle it opens a small valve to allow normal pressure air into the back side of the diaphragm. This imbalance of pressure is what gives you the added aide in applying the brakes. Ok class is over...
That said... it sounds like the booster valve is allowing in, a small amount, of normal pressure air in when it gets hot applying some pressure on the master cylinder rod locking the brakes.
I say booster is bad.
