A/C and Cooling Fans Vibration?
Ok, so I haven't owned my X-type long, but it has been getting warmer here and the fans have been running more. Do the fans on these cars vibrate a lot? No report of any front end collisions. When both fans are running you can definitely feel a lot of vibration coming through the steering wheel and hear it too. Not a huge deal, just wanted to see if this is standard. It looks like the fans connect to the radiator and I can push and pull everything front to back by about a quarter inch. Are there radiator rubber bushings/supports that need replaced? Thanks for the help
There are 2 lugs on the left and right sides of the cooling fan shroud for mounting to the radiator. There should be no play unless they are not properly installed or damaged from previous work.
There are 2 isolator rubber mounts on the top and bottom corners of the radiator.
I would also visually check for damaged blades on the fans. That would cause vibration.
The vibration you're seeing could be a worn bushing on one of the electric fans. I found one recently when I had to replace the radiator in my '04. Replaced the fan with a used one from local forum member motorcarman. Sure sounded nice when I got it all back together. Radiator comes out through bottom of car, but I'm not sure you can take the fan shroud assembly out the top by itself. Maybe someone else will advise.
https://www.jaguarforums.com/forum/x...cement-174689/
Bearings that the fan shaft spins on. The shaft on one of my fan motors was very loose. I attempted taking the motor apart but the fan was seized on the shaft. I lucked out with motorcarman who had a replacement motor and fan. Easy swap out. I suppose there's other options but this fix worked well for me.
Nope I pulled it from the bottom. It's actually a pretty easy job. I disconnected my top radiator hoses as I was installing new ones anyway. Pulled the bottom plastic cover and wrapped bungee cords around the radiator and top brace, disconnected all of the fan wiring, dropped the bottom radiator brace and then pulled the fan out. It's a tight squeeze, but take your time and you shouldn't bang up the radiator. Put the control box on the new fan and install.
