Cable not connected, where does it go?
Old May 6, 2010 | 02:31 PM
mikenmikena's Avatar
Default Cable not connected, where does it go?
Hello everyone I am needing some help. I recently took my air intake off to replace the intake manifold upper and lower seals because of a check engine code. I also replaced the spark plugs and replaced the valve cover seals and the coils. I put it back together and went to start it up. I get power and can hear clicking but it will not start. I opened the hood again and found a wire not connected. I can not for the life of me find where it goes to. It comes out from under the battery and off the cable that connects to the positive battery lead. I have all the other plugs in and there is on connection even close to it. I will upload a pic generalizing the area. I think the green arrow points to the cable. I will check and confirm. if anyone could tell me where it goes I would be more than thankful!
Old May 6, 2010 | 03:41 PM
DavidMoo's Avatar
Default that doesn't go anywhere on my x type too
I have a 2litre petro, there must be something funky on a 3 litre model that needs an extra sensor
Old May 6, 2010 | 06:51 PM
jonre's Avatar
I have the same wire right next to my battery box, mines goes no where and it just hangs there. But i dont think that red screwdriver goes there.
Old May 6, 2010 | 09:35 PM
mohrd's Avatar
Check the back of the battery box, slightly right of center, just below the cover. You will find the female end where it plugs into. Have no idea what it does but just had mine disconnected when i was playing with the positive cable.
Old May 27, 2010 | 04:15 PM
ok found the cable but car will not turn over, just get clicking sound from ignition. Not sure what it could be at this point.
Old May 28, 2010 | 12:14 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Sometimes the obvious is the Devil in the works. Maybe put a charger on the battery for a few hours!
Hope that is all it takes, Best 'o Luck!
Old May 28, 2010 | 08:19 PM
motorcarman's Avatar
The plug is for the battery isolation device that was removed from the car when the PDI was performed by the selling dealer. It plugs into a blank plastic connector behind the battery. The battery needed to be disconnected for the long journey accross the Atlantic on a freight ship and the isolation device performed this task.
bob gauff
hafren
23
Jan 3, 2025 11:26 AM
bamforp
Aug 14, 2024 05:36 PM
mbergen
Oct 23, 2019 10:26 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
British Ride
XJ40 ( XJ81 )
Sep 18, 2015 01:57 AM
