Can not remove a ebay buying Key from ignition! Please Help!
Old Jun 20, 2009 | 01:07 PM
patrick12's Avatar
Default Can not remove a ebay buying Key from ignition! Please Help!
Hello,
i buy this key from this ebay seller:
http://cgi.ebay.de/ws/eBayISAPI.dll?...m=250441875902
He cut it for me, very blowzy, i think with hand and file:
http://s2b.directupload.net/file/d/1...3frner_jpg.htm
http://s11b.directupload.net/file/d/...so3kaz_jpg.htm
i was making this photos because the key insert was was very hard and to protest.
Now i insert the key in the ignition and can not remove it.
I called a key and lock service, this man try to remove the key without success. He says only Jaguar can make it.
I can move the key from Position 0 to startposition but the car doesnt start because the key is not programmed and i have the message "security failed".
To program this key i need to remove it....
Is it possible with a trick to programming this key?, then i can drive the car at least.
Sorry for my english.
Old Jun 21, 2009 | 05:18 AM
jimmy's Avatar
ud
I dont know what else you can do except for pull hard.....
does the seller have any ideas?
Old Jun 21, 2009 | 07:55 AM
PositiveG's Avatar
Man that sucks, pull hard, maybe spray some WD-40 in there???
Old Jun 21, 2009 | 02:16 PM
Jamey's Avatar
I just suggested this for someone else with a Jag key, but it might be worth a try.
You can try rotating the wheel back and forth slowly until you find a sweet spot that will allow you to turn the key. Use one hand to turn the wheel and the other on the key, using gentle pressure. Finding it first time, may take a bit of time, but you'll know where it is the next time.
Good luck...I hope you're able to remove it.
Old Jun 21, 2009 | 02:17 PM
MeatBag's Avatar
Default Instructions that once saved me...
Instructions that once saved me... I read somewhere that if the battery in your key fob is dead for too long (not sure how long) you may have to reprogram after replacing the battery, and sure enough, i did have to. it was fairly easy and it worked like a charm.
Originally Posted by FearTheLeaper
If for some reason you need to re-program your remote after changing the battery, I posted some instructions on a previous thread. Here it is: https://www.jaguarforums.com/forum/s...ghlight=remote
There are also instructions in the FAQ section.
Old Jun 21, 2009 | 02:45 PM
patrick12's Avatar
the problem was the blowzy cut key.....the key/lock service removed this key.
Old Jun 21, 2009 | 05:57 PM
BuckMR2's Avatar
How did they do it?
Old Jun 22, 2009 | 01:56 AM
patrick12's Avatar
He asking me: "can i do it with power? it is possible that it breaks", i allowed.
I had luck, nothing breaks and the old key works fine as before....
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Numwen
Sep 6, 2015 12:30 AM
Bcrary3
Non-Jaguar Vehicles
Sep 3, 2015 03:07 AM
