Canadian 2004 X-Type DRL query
Old Aug 12, 2018 | 11:32 AM
DrVertigo's Avatar
Default Canadian 2004 X-Type DRL query
Hi All,
Can anyone tell me what is the normal status for DRL (daytime running lights) for a 2004 Canadian X-Type?
Should the low beam headlights always be on, or just the small (much dimmer) lights that are inside the high-beam headlight enclosure?
For the last two years, mine functioned as per the latter example, but after some recent electrical work (including cleaning many fuse box contacts, having the battery disconnected for some hours (ECU reset?)), now my lowbeams are on whenever the key is on...is this normal for this model?
I do not desire the new behaviour. For example, when driving through a campground at dark, I wish to be able to turn the lights off and not blind other campers. I'd prefer to have control over my headlights.
Appreciate any advice.
Thanks,
Julz.
Old Aug 12, 2018 | 12:33 PM
sov211's Avatar
Originally Posted by DrVertigo
Hi All,
Thanks,
Julz.
On the Canadian Jaguars ALL the lights are ON all the time (on more recent models, only when the transmission is out of PARK) - headlamps, sidelights, rear lights, license plate lights, and, depending on model year, the dash lights may also be on (on 2002 cars, for example, but not on 2005 and later cars - not sure about the 2004). So it is correct that your headlamps should be illuminated at all times when driving ... so you'll have to find a different solution for stealth entry to the provincial parks!
Old Aug 12, 2018 | 12:36 PM
Dell Gailey's Avatar
I already told you this in your other post, but here you go to read it for yourself =
https://www.jaguarforums.com/forum/x...lights-157246/
Wide_Tyres_2
Sep 19, 2016 08:11 PM
SiHarvey
Mar 29, 2015 11:45 AM
fairnie01
Jan 23, 2014 06:54 AM
XSMULLX
UK & Eire
Nov 18, 2013 03:57 AM
Wattie
May 6, 2013 03:45 PM
