Cant get lower air control valve out!?!?
Old Oct 28, 2008 | 10:29 PM
scubayachts's Avatar
Default Cant get lower air control valve out!?!?
I just received my o rings that go around the leaking upper and lower air control valves. I got the upper one out and replaced no problem but the lower one hits something when im pulling it out not and not allowing it to come out??? Is there a trick to this? Thanks everyone!
Old Oct 28, 2008 | 11:05 PM
rosemont83's Avatar
Default RE: Cant get lower air control valve out!?!?
just cut the old one and slip the new one on carefully over the imt so it doesn't snap
Old Oct 29, 2008 | 08:21 AM
jahuertas's Avatar
Can you post a pic where these located?Thanks.
Old Oct 29, 2008 | 09:52 AM
So should I just pull the lower control valve out as far as I can cut the original o ring and try to strech the new one over it to get it on????
Old Oct 29, 2008 | 01:10 PM
Alright it worked I just stretched the new seal over the IMT and cut the old one off. All sealed up now!
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Corycarlo
Sep 5, 2015 11:41 AM
XFR_Gold
Sep 2, 2015 12:24 PM
