Car not driving well after driveshaft replacement
Old Aug 20, 2016 | 04:35 AM
Lubino Do Rego's Avatar
Default Car not driving well after driveshaft replacement
Hi . I'm looking for some advice on this issue please. I replaced the drivers side driveshaft and lower ball joint however when I put it back together, it felt very different. I felt that the steering wheel was not in the straight ahead position by about 20 degrees or so and it felt a little disconnected from the road. I decided not to drive the car until I could find out what has happened . Any suggestions welcome.
Old Aug 20, 2016 | 02:45 PM
Larry-Cleveland's Avatar
I would go back over your work. Make sure everything looks right and is tight.
If you do not find anything have an alignment shop take a look at it.
Old Aug 23, 2016 | 12:49 AM
Thanks Larry for the advice. I had a look again and it appears that the outer track rod end has failed. The bolt and nut are spinning together. I am going to replace this and then review the situation. The other side will of course need to be done too.
Chuck Schexnayder
Feb 28, 2021 10:27 PM
silversurfer1221
Apr 6, 2016 05:26 PM
Humy
Oct 8, 2013 10:38 AM
chprman
May 1, 2008 05:23 PM
Oct 4, 2006 12:42 AM
