car overheates once in a while
Old Apr 25, 2009 | 04:49 PM
perezrp101's Avatar
Default car overheates once in a while
yea my car overheats but once in while what would cause my car to overheat is it the water pump but it cant be woudnt it over heat all the time
Old Apr 25, 2009 | 05:53 PM
Thermo's Avatar
Veteran: Navy
perez, do you notice when it overheats that you have been sitting for awhile, shortly after getting off the highway, or when on the highway. Each of these indicates a different thing. Let me know when it is overheating and we can take things from there.
Old Apr 25, 2009 | 09:34 PM
perezrp101's Avatar
Default replying heat up car
well started when i has in traffic the car started to heat up but the traffic started to clear up and got the car going faster it started to go back to normal but after that it didnt heat up for a week till today it started doing that
Old Apr 26, 2009 | 07:19 AM
Thermo's Avatar
Veteran: Navy
Ruben, I would check to make sure that you electric fans are functioning. Sitting in traffic at idle/very low speeds and having the vehicle overheat is a sign of bad fans. When cruising down the highway you won't see the problem as the air flow across the vehicle is sufficient to cool the motor.
If your fans are functioning properly, then it is possible that your water pump has corroded enough that the blades on the impeller are almost gone and at idle there isn't enough of the blades left to get adequate flow. But, get the engine RPMs up and it can then move the water sufficiently to keep the motor cool. But, I am placing money on the fans being your issue based on what you are describing.
Old Apr 26, 2009 | 10:20 AM
jimmy's Avatar
ud
remember the temperature gauge lies... it is a massaged signal, so that it does not move to the red area until the car is truely too hot.
The gauge is programmed to stay dead centre as long as the car is somewhere in the "normal" zone.
If it gauge is moving to the red, stop immediately, or you will do damage.
replace the thermostat, it is cheap, easy to do, and a common problem.
Old Apr 27, 2009 | 02:20 PM
perezrp101's Avatar
Default how do you change the thermostat
can you help me but i was checking the water pump their seems to be a whole on the water pump looks like a screw was on there what that be my problem
Old Apr 27, 2009 | 04:39 PM
jimmy's Avatar
ud
There? their? they're?
Whole? hole?
LOL
Old Apr 28, 2009 | 12:10 AM
mohrd's Avatar
bojangles? that you?
BrentGardner
29
Dec 16, 2024 12:13 AM
aholbro1
Sep 24, 2019 12:07 AM
jdzubas
Oct 4, 2015 09:14 AM
Jaguila
Sep 5, 2015 06:16 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
