Car wont shift to 5th gear once in a while
Old Dec 7, 2009 | 12:29 PM
85_305's Avatar
Default Car wont shift to 5th gear once in a while
Out of nowhere the car randomly holds 4th gear way long, then eventually will put it into 5th gear. Does this have to do w/ my CEL on for a lean condition (caused by I believe my pcv being cracked) ?
I hope my trans isn't going!
Matt
Old Dec 7, 2009 | 02:32 PM
The Chris X's Avatar
Is this with the Sport mode putton depressed? It will hold gears longer if that is the case.
If you have a known PVC issue/CEL my suggestion would be to address that first and then determine if additional diagnosis is warranted for other conditions. Cut down your variables.
Old Dec 7, 2009 | 03:24 PM
85_305's Avatar
No it is not. But my issue does only seem to be when the car is cold. It will drive at fifty mph at like three k rpms and just not shift.
But excellent input I'll do that first I suppose
Old Dec 8, 2009 | 06:39 AM
Ah, yes that is something I have experienced as well when the car is cold and not in Sport mode. Actually when its cold the tranny tends to do some odd shifting. I chalk it up to thick tranny fluid since it goes away once it is warmed up.
I wouldn't be too concerned.
Old Dec 8, 2009 | 06:52 AM
85_305's Avatar
oh ok so no need to worry? Phewww thats a good thing!
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
GuernseyJag
Nov 8, 2017 10:40 AM
jdzubas
Oct 4, 2015 09:14 AM
msdg137
Sep 16, 2015 06:24 AM
