CD changer problem Pls help!
Old Aug 16, 2008 | 02:24 AM
Jaggyx's Avatar
Default CD changer problem Pls help!
Hi,
I need some help with my cd changer.
I have a six disc jaguar cd changer and for some reason it is not working.
I took it to circuit city and the guy said that the cd changer wasn't loading
and reading the discs. Has this happened to anyone before?
Also, since I have the premium sound package made by alpine could I replace
the OEM jaguar cd changer with an aftermarket alpine cd hanger? And if so does
anyone know a compatible alpine?
Any suggestions would help!
Thanks,
Jim
Old Aug 16, 2008 | 03:07 AM
redjagsport's Avatar
Default RE: CD changer problem Pls help!
same thing happened to me
got someone to check it out
and the slot was broken
needed to be replaced
i bought a 10 disc cd changer instead
Old Aug 16, 2008 | 11:19 AM
Jaggyx's Avatar
What cd changer did you replace it with?
Old Aug 16, 2008 | 03:24 PM
http://www.etronics.com/p-32758-sony...ceGrabber&
everything had to be rewired
cuz the control system is diffrent
Old Aug 16, 2008 | 07:45 PM
BuckMR2's Avatar
the jag system is different from other makes as it uses a fibre optic cable to connect the cd-headunit-speedo-nav(if you have one)-voice control(if you have it).If one og the links is broken the whole D2B system will go (0)(0)'s up.
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
Dz1rfj
Sep 16, 2015 03:44 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
YycXJS
Sep 7, 2015 09:58 AM
