Chain cover removal
Old May 11, 2024 | 09:54 AM
Monkfish's Avatar
Default Chain cover removal
Quick question. I'm removing the timing cover and I've undone the 15 front bolts holding the cover but their are two more from underneath via the sump. Do I need to drain the oil? I'm removing the heads and thought I didn't need to drain the oil for this procedure and there's conflicting info on the net as usual.
X-Type 2005 3.0 litre
Old May 11, 2024 | 03:35 PM
Thermo's Avatar
Veteran: Navy
MOnkfish, you should not need to remove the oil from the engine, but hte oil level is going to be pretty close to where those bolts are. So, if the car is sitting a little down towards those bolts, the oil level may be high enough to come out. So, remove the bolts, but have a small pan capable of catching say a quart of fluid handy.
olico
Oct 23, 2023 02:05 AM
Jbm417
XJ40 ( XJ81 )
Nov 7, 2022 07:55 PM
RodL
Oct 23, 2021 06:08 PM
barbeerh
Feb 24, 2014 04:34 PM
osyris
Nov 27, 2013 09:43 AM
