timing chain cover remove
Old Oct 19, 2023 | 03:24 PM
olico's Avatar
Default timing chain cover remove
hello does anyone no if it‘s possible to remove the timing cover on a 2.8l 1970 engine without removing the cylinder head ?
Old Oct 19, 2023 | 09:18 PM
Jagboi64's Avatar
If you weer able to remove the studs that go up through the head, then you could. With the studs in place it would be very difficult. You might be able to remove them then by double nutting the stud and backing it out of the timing cover that way.
Old Oct 23, 2023 | 02:05 AM
olico's Avatar
ok, thank you it worked i removed the studes and the sump
RodL
Oct 23, 2021 06:08 PM
Luis LCG
Jun 11, 2020 01:44 PM
JensenHealey
Jan 12, 2019 11:48 AM
Daim
Jul 30, 2017 10:36 AM
barbeerh
Feb 24, 2014 04:34 PM
