Check Engine codes
Old Mar 20, 2007 | 07:58 PM
altownsend's Avatar
Default Check Engine codes
2002 X-Type 2.5 Automatic
I have been getting a light in the dash cluster. It is a red circle with an exclamation '!' in the midle. this had happened three or four times in the recent past. The throttle was non-responsive, and the idle was high. I shut the car off for about one minute and started it up again and it was fine. this happened only when starting the car in the morning for the first time of the day.
Today, It happened twice. This time, the check engine light came on. I got the codes and they were:
P0121
TPS Pedal Position Sensor a CKT Range/Perf
P1111
Manufacturer Control fuel Air Metering
Please advise my problem/solution - Thanks
Old Mar 21, 2007 | 12:22 PM
bigdreams05's Avatar
Default RE: Check Engine codes
I'll move this to the X forum where you might get better help!
Old Mar 21, 2007 | 10:49 PM
racerx82's Avatar
Sounds like your TP sensor needs to be replaced...
Old Mar 21, 2007 | 10:57 PM
andersen06's Avatar
Where would we be without codes...
Old Mar 21, 2007 | 11:00 PM
racerx82's Avatar
Scratching our heads and trying to figure out what part is bad! lol
Old Mar 21, 2007 | 11:01 PM
andersen06's Avatar
I miss the good ole days...
Old Mar 22, 2007 | 11:49 PM
ORIGINAL: andersen06
Code - LESS?
lol
JC
Old Mar 24, 2007 | 03:30 PM
altownsend's Avatar
the dealer told me that I had to change out the entire throttle body. Is this true? I certainly hope not. Seriously folks, can someone help with this.
Old Mar 24, 2007 | 08:00 PM
racerx82's Avatar
Iheard of this before...welcome to the world of owning an "exotic" auto...lol
What was the cost? 400?? Ask them to verify that in replacing this part, it will clear your codes....
Old Mar 29, 2007 | 08:38 PM
Envy337's Avatar
Jag does not sell the TPS seperately. Your best bet is to get it from a junkyard.
Old Mar 29, 2007 | 08:40 PM
Envy337's Avatar
P1111 is nothing to worry about.
Old Mar 30, 2007 | 12:47 AM
altownsend's Avatar
The car has been running fine for the past few days. No check engine light, nor the (!) light. today, the (!) light came on and I had the same experience with the throttle. do I have a short, or maybe a problem other than the TPS?
Old Apr 12, 2007 | 02:35 PM
Humy's Avatar
how do you guys pull up the codes?
Old Apr 12, 2007 | 06:14 PM
OBDII auto scanner. ~$100
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Dec 6, 2021 07:13 AM
jehart49
Sep 12, 2015 05:36 PM
dcvickers
Sep 2, 2015 06:14 PM
TC Johnson
Sep 2, 2015 09:30 AM
