Check Engine Light - Misfire
Old Jan 14, 2011 | 02:12 PM
Strafe's Avatar
Exclamation Check Engine Light - Misfire
My check engine light came on. I had it checked and the diagnostic said it was a misfire. The mechanic couldnt figure out why. So he reset it to see if it would come back. About a week later it did.
The car is running fine. No sputtering or hiccups or anything like that.
The second time it came back on was right after I filled up with gas. I use 87 octane. Could that have anything to do with it or just a coincidence?
Anyone have any clue as to what's going on?
Thanks!
Old Jan 14, 2011 | 02:41 PM
sidewalkman's Avatar
The car requires premium gas, 89 is the recommended minimum so yeah, that might be the cause. Doesn't seem to like ethonol either.
Old Jan 15, 2011 | 03:35 PM
Strafe's Avatar
The check engine light went out on it's own today. Could this be electrical? I didnt think those lights ever went off without being reset by a mechanic.
Old Jan 15, 2011 | 05:22 PM
totalimmortal363's Avatar
Don't most/all OBDII vehicles turn off the CEL after three run cycles without the fault??
Old Jan 15, 2011 | 05:44 PM
sport30's Avatar
Banned
the different codes have different priority, and severity. some reset never, some after one start some after a few starts, and some have complicated scenarios before they might go off.
There is no real reason to suspect that the light is for the same reason each time. The only way to know why the light was on is to read the code. If the light went out, the code will still be stored in memory.
is there not a fairly BOLD sticker on the gas filler door that says USE PREMIUM UNLEADED ONLY ??????????
Old Jan 15, 2011 | 05:58 PM
Strafe's Avatar
Yeah..of course..but sometimes I cant afford to fill up with the good stuff. Times are tough ya know.
Thanks for the help. I'll have the code read when I get my brakes done. See if it says anything other then misfire.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
dpappyp
Aug 27, 2015 06:31 AM
