clunky noise from drivetrain.. could this be the end of my Xfer case?
Old Feb 6, 2010 | 02:00 PM
matl's Avatar
Default clunky noise from drivetrain.. could this be the end of my Xfer case?
Hi guys, my 02 has 100k miles on it. Today i noticed a bit of a clunking noise when accelerating, sounded almost like a bad axle but it doesnt do it when turning as much as in just a straight line. Could this be the Xfer case? I jacket the car up and the axles looked intact. Also what are your oppinions on purchaseing a used case on ebay? I fear given their short life span that buying a used one might just present the same issue. But the price difference is substantial. Thank you. Mat
Old Jan 28, 2012 | 12:49 PM
03Xtype's Avatar
I'm noticing a similar noise on my 03xtype. clunking, ticking snapping noise between 20-30mph. It doesn't happen if you keep it in 2nd, all other gear selections it makes the noise.
Did you ever figure out a solution to your problem?
Old Jan 28, 2012 | 05:43 PM
03Xtype's Avatar
I found all the allen head bolts ready to fall out of the drive shaft front universal joint. After torqueing them to 40nm about 90% of the noise is gone after driving about 20miles. I suspect the remaining noise is due to some damage done to the universal joint and or alignment issue of the driveshaft.
Old Feb 7, 2012 | 04:42 AM
edge1212's Avatar
Its most likely not the transfer case. I just had mine go out at 100k miles however. It started to whine under acceleration and progressively got worse over time until BOOM its life ended. Jaguar Dealership wanted $2933 for a used case with 90k miles, or $4332 for a new factory remanufactured part. Those numbers include parts and labor.
If you ever hear a noise, its best to take it into the dealership and have it diagnosed, because they will almost always diagnose it for free, saving you the time of going through forums etc.. then you can decide your fate from there.
Hope this little bit of info helped!
Old Feb 7, 2012 | 08:09 AM
pab's Avatar
pab
I agree with edge1212, when my t-case went out last year it sounded just like a failing wheel bearing (whine coming from the direction of the front suspension while under power). I took it to the dealer, before it got really bad, because I assumed it was "just" a wheel bearing.
Needless to say I was surprise when I got their diagnosis. Good thing my car was still under factory warranty...
Jaguar: Grace, Pace, and Space - Sir William Lyons
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
raulan
Sep 10, 2015 12:43 PM
mrplow58
Sep 9, 2015 11:27 AM
