Clutch change time.
Old Mar 27, 2019 | 05:35 PM
Yorkiemark99's Avatar
Default Clutch change time.
Hi all , my clutch is slipping so I have bought a Valero solid flywheel conversion kit. Is it easier to remove the engine and box or remove the subframe then gearbox ? 2008 2.2d sport..
Old Mar 27, 2019 | 06:48 PM
DUNKS's Avatar
Hi wherever you are! I have heard that the solid flywheel can give you crankshaft trouble with a diesel.
Old Mar 27, 2019 | 10:01 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...clutch-103071/
I heard changing from dmf to single is more a problem of slightly more vibration and louder sound harmonics on some cars. Single will also allow you to machine it if replacing the clutch in the future, but I think that's a very minimal advantage given a normal clutch is good for around 150,000 miles or so. The larger concern is the transfer of torque to the driveshaft and crankshaft as Dunks mentioned. It is particularly a problem with newer (when implemented) smaller engines that produced much more horsepower and torque than their predecessors.
Good explanation =
Here's a brief explanation of the differences =
aholbro1
May 19, 2021 02:30 AM
cujet
Jun 5, 2017 07:12 PM
MannyJag
Apr 18, 2016 10:17 PM
caimano
Apr 26, 2012 11:09 AM
speedyxjs
Jan 28, 2011 11:08 AM
