Code Help Please
Old Jun 25, 2015 | 05:59 PM
mjan's Avatar
Post Code Help Please
Dear all,
my x type 2004 patrol,2.1 wont crank wont start, tried everything spend money calling mobile mechanics in my area battery checked by Halfords its good, starter motor ok, fuses are all fine, first It was troubling me with starting then all lights on the dash but no crank no start now no lights at all except the air vent lights on the immobiliser has disappeared, no crank no start codes that came up on the reader were, U 1900 CAN BUS FAULT, P1637 CAN ECM TO ABS/TCM,P1260 SECURITY INPUT MAL FUNCTION. don't know what's going on I have already spent £300 still no sign as to what is all causing this. Its a headache,Can someone please help.
Old Jun 25, 2015 | 06:48 PM
mjan, I've deleted all your other posts, please do not post the same thing all over the forum.
Did this happen suddenly or did you do any work on the car?
Old Jun 25, 2015 | 07:23 PM
mjan's Avatar
Default can bus fault, security malfunction
DEAR NOORI,
Thanks for the reply, it started playing up for the last few weeks and now the result is no crank no start no dash lights no immobiliser lights just the ac fan works.
Old Jun 25, 2015 | 07:34 PM
mjan's Avatar
As far as I number, couldn't change one of the spark plugs underneath the manifold during last years service because of playing up bolt on the manifold and last week did a engine steam wash from beneath where the sump pan is to check the oil leak and it was unfortunately sump gasket where the oil was leaking from.
Old Jun 26, 2015 | 07:22 AM
Thermo's Avatar
Veteran: Navy
mjan, if you are getting lots of lights on the dash (pretty much all of them) as you are starting the car, then based on your codes, you are most likely looking at a bad ECM. What it appears to me is that the ECM is seeing the voltage at the ECM drop too far and this is putting it into a diagnostic mode and it is checking all the lights to see if they work. This is resulting in a communication error (hence the P1637 and P1260 codes) and the start signal between the security module and the ECM is not happening. Without this signal, the ECM never sends a signal to the starter to roll the motor.
On a side note, the U1900 code is a common code that I have seen in every car I have dealt with. I would say to ignore that code for the moment.
Old Jun 26, 2015 | 03:40 PM
astromorg's Avatar
I wouldn't disagree with Thermo's suggestions, but it could also be that your ignition key has lost its programming to the car (Not the key fob, but the transponder in the key itself) Have you a spare key to try? If not it requires specialist equipment to do the programming.
Also, check the connection to the ABS Module in the front righthand corner of the engine bay to make sure it's clean and properly connected and the wiring in case of damage
Old Jun 26, 2015 | 04:07 PM
Thermo's Avatar
Veteran: Navy
Astro, if the programming was lost in the key, it should be giving him a message in the message center about "Security Enabled" or something to that effect as it is not getting the correct message from the key. I forget the exact message that comes up when a properly programmed is not used. It seems to me that the center console will also flash a red light which he is saying he is not getting. Hence why I went for the ECM as the likely suspect.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
