Cold air intakes, and turbos
Old May 17, 2009 | 04:44 PM
Disco stu55's Avatar
Default Cold air intakes, and turbos
Has anybody added a cold air intake which?is what i would like to do since it will be more effeincit and a bit more power or a short ram air intake, which i would purchase. andhas anybody installed turbo out of curosity. And if u did add the caold air intake or short ram intake , where did u find the airbox for the car, and did u relocate the new one.
Old May 17, 2009 | 05:48 PM
Thermo's Avatar
Veteran: Navy
Disco, people have added the cold air intakes to their cars with little to no positive gains. Sure, you get a new look, but that is about all the gain that you are really going to get. You are better off removing the baffle inside the air box and go from there. Cheaper and you net the same results if not better results.
As for turbo, seems to me someone did do a turbo, but the specifics I am not sure about. I personally would not recommend this unless you can figure out a way to make the transfer case a lot stronger.
Old May 17, 2009 | 06:26 PM
okay, good, becuuase i've heard mixed things about the cai,sri, what, and how can i remove the baffle, is there anything i should know about it, and is there any side effect, what are the pros and cons of doing this.
Old May 17, 2009 | 06:52 PM
racerx82's Avatar
I suggest you just replace the filter element with a K&N. Your stock intake is excellent in design and flows a a good bit of air as is. The filter is the restriction.
As for the turbo, forgetabout it. Best bet is to port your intake, bigger injectors, and if you're up for it, complete exhaust, headers, free flow cats and new mufflers.
Your exhaust is one of the most restrictive i have ever seen. You will free up approx 25 hp just by gutting the factory setup and replacing with aforementioned system.
Enjoy!
Old May 17, 2009 | 07:32 PM
Where can i get the k and N filter offline, like a local autoparts store, any recomenndations, and yeah the exhaust is very restrictive, but i can't really afford a 800 dollar transplant, yet, maybe in a few weeks, ut htreres no one around town who likes working on european vehicles. Once again how do i remove the baffle, any pros and cons to this.
Old May 17, 2009 | 07:40 PM
racerx82's Avatar
Do a web search. Local part store won't have them. I think i paid 40 for mine online.
Old May 17, 2009 | 08:24 PM
Okay, its just that i've never bought online, becuase of all the fakes, and other probelms, plus i don't have an paypal account
Old May 17, 2009 | 08:53 PM
racerx82's Avatar
Well....ah.....don't know what to tell ya.....
Old May 17, 2009 | 08:59 PM
Alfadude's Avatar
Here is a link to a guy that did a bunch of different mods on his car including smoothing the baffles in the airbox. Pretty interesting stuff.
http://jagmotorproject.blogspot.com/...breathing.html
I think I bought my K&N from Auotanything. Good price and free shipping.
Old May 17, 2009 | 10:05 PM
k thnx, by removingt he baffle what do u do
Old May 17, 2009 | 10:18 PM
Man i wish i had more mechanical experience, but it looks simple enough, wheres the airbox though, i have yet to find that, i've look everywhere, and im not quite used to certain mechanics of the jag yet.
Old May 17, 2009 | 11:10 PM
Master Deep's Avatar
K&N filters r sold at my local autozone and Advance Auto Parts. Check their website and see if your store carries them.
Old May 17, 2009 | 11:12 PM
Easy. Take off the engine cover. Then right in front (Right behind where the grill is) you will find the airbox. Take off the 4 or so screws and change the filter. You can see where the airbox is w/o taking anything off first. It's a small rectangular box right behind the grill.
Old May 17, 2009 | 11:14 PM
I highly suggest you download the JTIS service manual. Everything is in there for the most part.
https://www.jaguarforums.com/forum/s...ead.php?t=4172
Old May 18, 2009 | 09:34 AM
okay, becuase i was looking for the airbox,, turned out ot be the battery, big goof up
Old May 18, 2009 | 09:54 AM
racerx82's Avatar
It's probably a good idea you just stay away from doing any engine work on your jag. This project is simple, but if you don't have a clue and mess up something...or don't clean up the shavings and what not.....if can get all sucked up into your intake and you'll be dead in the water.....
Just drive the car and enjoy.
Old May 18, 2009 | 04:28 PM
Hey Racer where is the Pollen filter? I found another thread describing where it is but I still can't find it.
And is it easy to change? All I know how to change really is air filters and do oil changes. This car is a bit more confusing than older cars so I'm scared to experiment with harder stuff.
Old May 18, 2009 | 04:56 PM
Nervermind I found it. But I don't know if I want to mess around with changing it. Dealer wants $100 for what is basically a filter and 5 min job. How much does the pollen filter part cost from the Jag dealer?
Old May 18, 2009 | 06:37 PM
Thermo's Avatar
Veteran: Navy
Disco, open the hood and look at the center of the radiator from the top. You will see two small openings (about 2x4", oval in shape). Follow these straight back towards the motor and when you run into a plastic box that says "Jaguar" on the top of it, that is the air box. Remove the 4 screws holding it in place and lift straight up. That will expose the air filter. PUll out, install the new filter.
As for finding a K&N filter, go to any local auto parts store and if they don't have the filter sitting on the shelf (that is where I found mine), you can go to the counter and have them special order it for you.
Old May 18, 2009 | 07:55 PM
thanx, yeah i was thining of just geting mechanics to do what i needed to do, but eh air filter replacement sounds pretty easy
