Control Arm Broke
Old Dec 26, 2007 | 10:17 AM
hooutoo's Avatar
Default Control Arm Broke
Wife hit two curbs and damaged both rims and broke what I believe is the control arm on the front left side. I'm mechanicly inclined and don't want to spend $$$$$ at Jag dealer. Ialready got wheels from Fleabay which won't be here untill Jan.3. How difficult to change, tools needed, best parts? The car is already up on jack stands in my garage and I've included picture of broken part. Any advice would be greatly appreciated?
Steve
[IMG]local://upfiles/2740/AFA1F09CFB87408CA0A17B48AD070224.jpg[/IMG]
Old Dec 26, 2007 | 11:04 AM
RudyF6's Avatar
Default RE: Control Arm Broke
If that is a result of a curb hit, I'd be VERY surprised if that was the only damage. Get your rims and that link done, and head immediately to a 4-wheel alignment shop. And have your insurance claim phone # handy! []
Old Dec 26, 2007 | 11:30 AM
hooutoo's Avatar
Thanks for your reply. Do you know if there are any special tools? I've managed to move the top bolt but it just spins in the bolt hole. The bolt must somehow be held in place so just the nut will move.There is aplaceon the end of the bolt for hex rench. Samething on the bottom but the whole thing is facing away from me and even more difficult.
[IMG]local://upfiles/2740/7CD96F643F58482CBF0FBCF87FB68D71.jpg[/IMG]
Old Dec 26, 2007 | 11:34 AM
hooutoo's Avatar
Rudy, Do you have any idea on the cost of alignment at a 4-wheel alignment shop? thanks
Old Dec 26, 2007 | 11:38 AM
RudyF6's Avatar
Put a little heat to that nut - probably loctited and that will help break it loose. If not, cut it off. Plan on anywhere from $80 to $100 for alignment - IF nothing is damaged..........
Old Dec 26, 2007 | 11:46 AM
hooutoo's Avatar
Thanks... will give it a shot!
Old Dec 26, 2007 | 02:22 PM
hooutoo's Avatar
Well I've managed to get both off. Its all a trick, you must first turnboth the nut and bolt so they both turn freely in the bolt hole. I used a ratchet and 15mm socket to break it free. Then just put a 15mm rench on the nut, insert the correct size hex rench and turn, off it came.
The most amazing thing is the control arm is made out of plastic, very hard but just plastic. I'm off to the jaguar dealer to see how much they sell plastic control arms for!
Steve
Old Dec 26, 2007 | 04:26 PM
hooutoo's Avatar
Guys, what was broken in the picture was the sway bar tie and that is plastic. $142 for the plastic at Gaudin Jag, Las Vegas.
Old Dec 26, 2007 | 07:06 PM
aquill1's Avatar
The control arm isn't plastic...it should be steel...the control arm in the future only runs like 220 at the dealer...for some reason the dealer isn't actually too bad on cost of parts its the labor that is helluvalotamonay!
Old Dec 26, 2007 | 08:31 PM
MarkC's Avatar
ORIGINAL: aquill1
The control arm didn't break...the sway bar end link broke. A Google search turned up several generic replacement end links for about $98... still an outrageous price for a sway bar end link.
Old Dec 26, 2007 | 10:26 PM
aquill1's Avatar
I saw that you didn't replace the control arm I was just letting you know for future reference. The control or lower control arm also has the ball joint with it...
Old Dec 27, 2007 | 09:36 AM
hooutoo's Avatar
Thanks guys for all the input. Yes its correct it was never the control arm, my bad. It was the roll bar/sway bar Link, which is nothing more than a plastic strap. When I talk to a awd alignment shop they laughed about it and said sometimes they don't even replace them, they're a joke. I don't know so I ordered it.
Markc, I searched google for the part which is listed on my jag part receipt, c2s39552and found nothing. Do you have the link for part you found?
Old Dec 27, 2007 | 12:39 PM
bigdreams05's Avatar
PLASTIC? GTFO!
Old Dec 27, 2007 | 03:28 PM
aquill1's Avatar
Seems weird to me too...i'll have to jack mine up and look at it...perhaps the next time I do an oil change!
Old Dec 27, 2007 | 04:48 PM
MarkC's Avatar
Hooutoo,
I Googled "Jaguar sway bar link", not the Jag part number. Here is a link...
http://www.autopartswarehouse.com/de...3-1657770.html
This part apparantly fits X-types from 02 throu 07.
I did a little more searching and found that Rockauto.com also lists the front sway bar link for about $71. This one actually looks like it is made of plastic.
http://info.rockauto.com/Spicer/Deta...?5451562-4.jpg
A broken link will not pass safety inspection in Pennsylvania (nor anywhere else vehicle safety inspections are required) and handling would surely be degraded. Replacing it is the only way to go.
Old Dec 29, 2007 | 10:10 AM
hankycbr's Avatar
you will probably need a 4 wheel alignment. I got mine from Firestone. i'm in the northeast US. it cost me $120 for a lifetime of wheel alignments as long as I own my jaguar. I thought this was a great deal. Its supposedly till the end of this month but i'm sure if you ask, they will extend this offer. You can go as many times as you want and for me in the Northeast, its a blessing with all the damm potholes.
Old Dec 29, 2007 | 08:24 PM
aquill1's Avatar
Yeah thats what I was going to say! I mean they may not be flawless at engineering the part but I'm sure if there were a problem with it going bad or it being unsafe to put plastic they wouldn't...can't really engineer a car for hitting things! Shoot my car can barely handle the pot holes here let alone curbs!
Jandreu
Jun 30, 2022 03:10 PM
ym37tech
Feb 8, 2016 01:04 PM
tiger4366
Sep 22, 2015 09:20 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
