Cooleant leak
Old Mar 11, 2009 | 05:06 PM
morales8416's Avatar
Default Cooleant leak
Yesterday i noticed a small wet small wet spot on my pavers. As i look underneath i locate a leak what seems to look like theromostat housing? What i am looking at is in front of the engine midway up looks plastic with two clamps in one end a hose comming down to a metal looking pipe that goes to what might be the radiater. Is this the thermostat housing i am looking at? i see wetness around and on top and below of the housing which looks like held together by 8mm bolts. Any ideas? 2002 3.0 xtype. If so is it easy change? whats the average Jagprice will do thiss change. Time is precious and not enough of it t do job myslef.
thanks
Old Mar 11, 2009 | 06:48 PM
Green Machine's Avatar
Red face
The thermostat housing is a triangle flanged piece, held in place by 3 bolts, with a hose going to the oil cooler attached by a clamp. I'm not sure what you're looking at, as the diagrams don't show anything like you're discribing. I have a 2003 2.5 but both engines are basically alike, I'd go out and take a look at mine, but it's too darn cold right now, even in the garage. Sorry I can't be of much help to you.
I've got a small coolant leak also, but mine is where I rigged up a new drain line to make it easier to do coolant changes. I'm going to rectify the leak problem just as soon as the weather warms up a bit.
thanks
Old Mar 12, 2009 | 11:15 AM
jfenley's Avatar
The Triangle area has the Thermostat inside.
Old Mar 12, 2009 | 02:42 PM
thats it i see exactly where that is and yes its the thremo housing. guess i will change that out but first i will check if the bolts are loose.
thanks
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Poet
Oct 2, 2015 09:00 AM
ahunt4
Sep 25, 2015 03:43 AM
arskemp
Sep 21, 2015 02:19 PM
Tim Goz
Sep 17, 2015 09:11 AM
