Crazy Alarm
Old Jan 17, 2009 | 10:05 AM
mvdennis's Avatar
Default Crazy Alarm
Hi guys ... i have a 2.1V6SE x-type. Over the last few days, the alarm would go off for no apparent reasons, but they usually happen only within around 10 mins from the time i lock the doors. The solution was to rush to the car, unlock, and then double-lock the car again.
Does anyone have this experience? And is there any ways to resolve this, or to shut off the alarm system completely? My car is just out of warranty, and i'm not really prepared to bring back to the dealer and them charge me an arm and leg to resolve this problem ..
Old Jan 17, 2009 | 10:08 AM
jvegas's Avatar
Default RE: Crazy Alarm
although i don't have a fix for your issue I have noticed that sometimes if my car is locked and I pop the trunk from the key fob the alarm goes off when I open the trunk. (that is a real long sentence)
Old Jan 17, 2009 | 10:23 AM
jag_genius's Avatar
basically something is triggering it.. easy things to check are under the hood.. there is a spring switch for the alarm.. the hood has a pad on it size of a quater which presses the the switch close when the hood is closed.. sometimes the pad falls off.. and the spring cant close a 100% . check that the trunk latch is closing good and tight and all the doors are closing and latching.. if you take it to the dealer.. ids.. can read what is actually triggering it.. under last known alarm activations..
Old Jan 17, 2009 | 10:27 AM
jag_genius's Avatar
check the barrel flap as well
mvdennis's Avatar
thanks .. but that doesn't seem to be the reason ... it's only a recent occurrence that the alarm goes off frequently. what's odd is that it happens only within the first few minutes of locking the car, and (thankfully) not one of those situations where it happens in the middle of the night ...
i really hope i can learn how to shut off the alarm for good ...
Old Jan 17, 2009 | 10:31 AM
mvdennis's Avatar
ORIGINAL: jag_genius
hi ... thanks for the suggestion! where is this spring switch again? left or right side of the hood? but the alarm doesn't trigger every single time the door is locked, but only occassionally (usually more so at night) and within minutes of locking the car .... are these still likely causes? also what is that barrel flap thing?
Old Jan 17, 2009 | 10:34 AM
jag_genius's Avatar
drivers side under hood .. in front of the reservoir .. barrel is where you stick the key to start it..
Old Jan 17, 2009 | 10:35 AM
jag_genius's Avatar
you should see a door there .. where you stick the key.. the door shud move when you stick the key in slightly if not wd40 can losen it up
Old Jan 17, 2009 | 10:42 AM
mvdennis's Avatar
thank you ... will try your recommendations. but is there no way to shut off the alarm for good?
Old Jan 17, 2009 | 10:46 AM
jag_genius's Avatar
even if there was.. it would be done through the dealer.. thru ids
Old Jan 18, 2009 | 10:52 PM
mvdennis's Avatar
ORIGINAL: mvdennis
I think i found the little rubber 'pad' ... didn't look like it wasnot attached properly, but i just adjusted it slightly and i haven't got the alarm activation since. i suppose it's still too early to tell, but pray hope this is okay from now onwards!
Old Jan 19, 2009 | 07:57 AM
mvdennis's Avatar
true enough ... as always when you think you solved the problem, it came back. oddly, i realised that the alarm only goes off when i'm parked at the carpark at my house! i've been parking there for 8 months now, and it's only these 4 days where the alarm would go off, and i'm absolutely sure there is nothing that activated it somewhat ... because whenever the alarm goes off, i'll just go 'unlock' and lock again ... and i never even touch the vehicle nor open its doors ...
i really dread bringing it back to dealer but looks like i got no choice now ....
Old Jan 20, 2009 | 08:04 AM
mvdennis's Avatar
i've made an appointment with the dealer because i really cannot fathom what's causing the alarm to keep sounding
over the phone, he can't decipher what's wrong with the car too ... but came up with a lot of various solutions such as checking the whole wiring system and all that which i think he just want to rip me off! Can someone please advise if it's firmed that IDS could disable the alarm system? If so, i'll ask the dealer to just disable the alarm if they can't decide what's wrong with the car ... please help!!!
baskervillema
Oct 1, 2015 06:43 PM
JagBrian
Oct 1, 2015 12:52 AM
John Fox
Sep 30, 2015 03:17 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
