Dashboard everything not reading
Old Feb 26, 2018 | 06:14 AM
Slownot's Avatar
Default Dashboard everything not reading
Engine idling all okay with no issues , then suddenly all lights come on on dashboard , battery warning light etc etc on.
Rev counter showing nothing and fuel and temperature gauge just as though key in ignition 1 section
Checked voltage at battery just on 15v idling
Switched everything off and restarted all okay with gauges working correctly , happened again about ten minutes later.
I am a mechanic so I understand anything technical information , just wondering if there's a known cause before I dive in I've only had the car a few months and love it , thanks.
Old Feb 26, 2018 | 10:21 AM
avern1's Avatar
I would start with checking the connections and solder joints on the ignition switch. It is acting like you turned the key off. Is the engine shutting down or continuing to run?
Old Feb 26, 2018 | 11:03 AM
Slownot's Avatar
Engine is continuing to run perfectly throws up a fault code of P1642
Old Feb 26, 2018 | 11:56 AM
jeremys's Avatar
looking at older threads it could be a loose connection at the CAN, which seems to be the communication circuit for other units like the Control Module as most people who reported this experienced other accompanying faults and restricted performance
Good Luck
Old Feb 26, 2018 | 12:59 PM
JagV8's Avatar
P1642 looks to be a CAN error and with the faults I'd be looking for a chafed harness (or maybe a bad connector).
You might like to get codes from the other modules read in case that helps pinpoint where the fault probably is.
Old Mar 5, 2018 | 11:05 AM
Slownot's Avatar
Would that be at the connector that's tucked down on the os with a torn connector on it ?
ferrarix99
Oct 8, 2012 09:52 PM
XJ40 Fixer
XJ40 ( XJ81 )
Aug 8, 2012 08:33 AM
KAZsam
Jun 9, 2008 08:07 AM
EDLFWood
Jan 10, 2008 01:13 AM
