Daytime Running Lights
Old Feb 3, 2014 | 11:30 PM
04xtype04's Avatar
Default Daytime Running Lights
Wondering if there was a way to run automatic daytime running lights. Doesn't seem like there's a good place to install any of those LED bar type running lights. Figured maybe someone came up with a way to convert the parking lights to running lights or something. I just want some running lights because I think they are safer and they look cool but it's not that big of a deal, I turn on the headlights sometimes when it's overcast or early in the morning. Just wish there was a way to have DRL's automatically turn on when the car's on. I think there might be a way to run a fuse from the fuse box to power on when the car's running but not sure how complicated that is a on a Jaguar.
Old Feb 4, 2014 | 07:19 AM
bracester's Avatar
Something like this?
DRL Relay DRL Module Daylight Running Lights Best Product on Market | eBay
They do make them, some are good just for LEDs and others for halogens as well...I have though about it too for my fog lights as DRLs since I pretty much never use them
Old Feb 4, 2014 | 09:36 AM
04xtype04's Avatar
Yes thank you. That is what I would need. Seems a little bit complicated with all the wiring but I guess if I really wanted them it's possible. Maybe a project for a rainy day. Also found this one with longer wires:
USA Made Truck Lite 97308 Heavy Duty Daytime Running Lights DRL Module Universal | eBay
Old Feb 4, 2014 | 10:32 AM
bracester's Avatar
Exactly. Its not too complicated if you think about it. Its just a giant relay that senses input from your headlights or running lights and kills power to the DRLs. So one set goes to your battery, the other to your headlights or running lights and then when you switch on your headlights or running lights it kills power to your chosen DRLs...not too bad but yes wiring is definitely involved.
Old Feb 4, 2014 | 10:41 AM
Fulton's Avatar
Up here in Canada daytime running lights are mandatory for vehicles imported under 15 years of age. All Jaguars in the US have this feature it just has to be turned on. The Jaguar dealer in Maryland switched mine on for free.
Old Feb 4, 2014 | 10:44 AM
bracester's Avatar
:looking for emoticon for worthless without instructions:
Old Feb 4, 2014 | 11:06 AM
Fulton's Avatar
Well ok, if you insist.
1. Get in Car
2. Drive to Jaguar Dealer
3. Ask them to put your car on the computer and turn on the daytime running light option
Old Feb 4, 2014 | 01:51 PM
Thermo's Avatar
Veteran: Navy
04xtype04, keep in mind that there are 4 different headlight switches for the X-Type. They all control the headlights different ways. How do you want the headlights to respond? What I mean by this is that the American (non-DRL) act just like you are used to in that they only turn on the low beams when in the ON position. Where you have the Canadian switch which has the low beams on all the time regardless of the headlight switch position. Then you have the Scandinavian version which allows the low beams to be on with the headlight switch in the OFF position and ON position, but goes to only running lights in the PARK position (this is needed for some people that enter through guard houses and are required to dim their headlights, especially true of military bases). It seems to me that there is another switch which is like the Canadian switch, but it also turns on all the running lights too. So, what are you after?
Old Feb 4, 2014 | 05:39 PM
bracester's Avatar
1. Get in Car
Now I didnt see that coming lol
Old Feb 5, 2014 | 07:40 AM
Fulton's Avatar
I'm glad you took in the jest as it was intended. If you have several dealers to choose from call around. The Dealer in Halifax NS. wanted $250 just to hook up to the computer but the dealer in Annapolis MD did it for free.
Old Feb 5, 2014 | 08:06 AM
bracester's Avatar
Oh ya all in good fun my friend. I didn't realize that it could be enabled rather than aftermarket....im not one for DRLs anyway
Old Feb 5, 2014 | 11:51 PM
04xtype04's Avatar
What most cars with DRL's have around here are the high beams run at 30% power during the day, then when you flip on the headlights at night, the low beams turn on and the high beams turn off and go back to being normal high beam lights. I would probably just do this, although I was hoping for an LED route. Not sure if you can use LED bulbs in the high beams with reduced power as DRLs. Also the problem is LED's aren't bright enough to function as real high beams if I ever needed them. I guess I would probably want my parking lights in the high beams to be my DRL's and just run some bright LED bulbs in it. I'm am ok at wiring, took an electronics class before and have a soldering iron, just not too familiar with the wiring on the x-type.
Old Feb 6, 2014 | 07:06 AM
bracester's Avatar
If you are looking for bright LEDs for the parking lights I just got some of amazon that are extremely well made.
Amazon.com: AGT 10x 194 168 2825 5-SMD White High Power LED Car Lights Bulb: Automotive Amazon.com: AGT 10x 194 168 2825 5-SMD White High Power LED Car Lights Bulb: Automotive
These are the highest quality ones I have seen and used and inexpensive
Old Feb 6, 2014 | 12:10 PM
04xtype04's Avatar
Alright cool. I have similar ones like that on the way, can't comment on the quality of them yet but they are the 5-smd 5050 bulbs. I got like 10 for $5 so I decided to do it. Was looking at the 9-smd bulbs but I think a pair of those ran $5 so I decided I would try out the 5-smd bulbs first since the side markers and license plate also use that size bulb. We'll see how they turn out. I'm also waiting on some bulbs for the brake lights, just ordered those a couple days ago but they should be sick. Probably want to do the rear blinkers too in a bright yellow next just cuz I like LED lights.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
