Is different transfer case fluid required for 02-03 models vs. 04-08?
Old Oct 14, 2010 | 12:52 AM
MattSteele's Avatar
Default Is different transfer case fluid required for 02-03 models vs. 04-08?
Given that the transfer case design changed substantially in 2004, does anyone know if the newer transfer cases use the same fluid as the earlier ones? Most of the transfer case fluid change threads on this forum involve older cars and call for JTIS Spec: M2C192A synthetic, SAE 75W140 synthetic gear lubricant.
Brutal, RealTech or any of the other Jag certified techs, if you're reading this thread, would one of you be able to confirm whether the fluid spec for the later cars is the same as the earlier cars, and whether there are any friction modifiers required? I've got a 2005 X-Type 3.0, and don't want to mess up the transfer case by putting the wrong fluid in it.
Thanks all.
Old Oct 14, 2010 | 05:06 PM
Thermo's Avatar
Veteran: Navy
Matt, the 04+ cars still require the same lubricant. So, get a good full synthetic 70W-140 gear lube and change away.
Old Oct 14, 2010 | 11:20 PM
MattSteele's Avatar
Thanks for confirming, Thermo! I appreciate it.
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
sogood
Sep 15, 2015 07:35 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
