Does Sat/Nav have infocenter functions?
Old Jan 8, 2018 | 02:03 PM
wa3ra's Avatar
Default Does Sat/Nav have infocenter functions?
The newer X that I'm looking at has the sat/nav, but no info center...
Are the info center functions available on the screen, or do I need to find a new display and switch pack to get them back?
Old Jan 8, 2018 | 07:18 PM
Dell Gailey's Avatar
I have sat nav. Info such as what?
Old Jan 9, 2018 | 07:29 AM
wa3ra's Avatar
Trip computer, gas mileage, distance counters
Old Jan 9, 2018 | 04:51 PM
The info you were curious about is listed just below the speedometer and is toggled between A & B on the headlight switch. You access the listed information by pushing the turn signal stalk button.
Old Jan 9, 2018 | 05:01 PM
Pics of info
Total mileage
Trip odometer
Range or dist. to empty
Close but no cigar. Actual math = miles devided by gallons to fill, I get 2-3 miles greater. This is from last reset, also.
Afg. Speed since reset
The setting of language (British, US, French, etc.) For this info should not be confused with the Nav voice setting. They are 2 distinctly different techniques.
Old Jan 9, 2018 | 05:11 PM
wa3ra's Avatar
Thanks. My 2002 has it, the new 2005 doesn't.
I've gotten very used to having it.
Looks like I need an instrument panel, switch, and programming to match the panel to the security and turn on the function.
Old Jan 9, 2018 | 05:28 PM
The Nav screen has buttons on left and right side of the unit. They show Nav, menu, audio, climate, phone, etc. As well as auto climate setting, manual fan (also on climate screen), front and rear defrost.
There is an additional info screen just below the nav screen showing time (duplicated on the nav screen), outside temperature, and interior temp setting).
And if you ever access the hidden Sat-Nav screen = never ever, never, ever.........did I mention? Never, ever, never, ever TOUCH THE S/W BUTTON on the touch screen = it is the black screen 50/51 error kiss of death.
Menu
Nav
Phone, but phone button on steering wheel does mute the audio if playing.
Climate
Audio
Info below Sat-Nav
Old Jan 10, 2018 | 10:57 AM
wa3ra's Avatar
Thanks! I'm guessing S/W is the command to flash the software from the SDS/IDS?
Old Jan 10, 2018 | 02:35 PM
Yeah, software update. In the year (almost) I've had my kitty and been on this, the best of the Jag forums, it boggles my mind how many times I've seen the "ACCIDENTALLY" touched the s/w button and now have blank screen with error code, lmao!!
Old Jan 10, 2018 | 02:37 PM
Btw, then "they" seem to never search for the solution, which is easy to find here and instructions on burning a CD for the fix.
Old Jan 10, 2018 | 03:24 PM
Alfadude's Avatar
"There seem to be a lot of "theys" that post a question on here before even considering doing even a rudimentary search first.
Old Jan 10, 2018 | 05:42 PM
wa3ra's Avatar
I don't even need to search, a have a clean KWI disk!
Wondering what the most recent valid NA map disk is? 2008, or does something later work?
Old Jan 10, 2018 | 08:54 PM
Last one (& ever will be) is 2012 =
Jaguar | Jaguar | Jaguar - North America Map DVD Version 2011-2012 | HERE
Old Jan 10, 2018 | 09:41 PM
wa3ra's Avatar
Gotta be more accurate than the 2003 in there!
brick
Nov 28, 2014 03:54 PM
Pinecone
Dec 29, 2013 07:34 AM
TheLegend
Aug 14, 2011 09:05 AM
Cough
Jun 22, 2008 05:26 AM
