Door 'Guard/Trim/Strip Removal Project....
Old Mar 26, 2011 | 10:44 AM
j_bond's Avatar
I'm still going to try it. If the holes are small enough, I will fill them and have it airbrushed. How big are the holes Jeremy?
Old Mar 26, 2011 | 01:35 PM
exexpat's Avatar
I would guess 4-5mm in diameter. It's just a little guide pin to ensure alignment of the rub strips.
Old Mar 26, 2011 | 06:46 PM
ghettomike's Avatar
so you have the fronts off but not the backs???
lets see some pics.
Old Mar 26, 2011 | 08:35 PM
j_bond's Avatar
Project TERMINATED.
The guide pins and the indention where the guards are removed does not look satisfactory
onto the next.....
Old Sep 11, 2011 | 12:38 AM
JasonERF's Avatar
Originally Posted by j_bond
Project TERMINATED.
onto the next.....
Could you clarify what you mean by indentation ?
There's more than just the holes? The body work indents around it?
I'm assuming to do this right you'd have to be properly repainting and filling in the holes before hand?
Old Sep 11, 2011 | 02:31 AM
Cambo's Avatar
If you stand behind your car, looking down the side, you can see that the door skins are "scalloped" i.e. long sweeping curves, but the center section where the trims are is slightly raised & flat. The shape of the door skin is interupted where the trim is. So when you take off the trim, you can clearly see where it was. Oh, and the holes!
Old Sep 11, 2011 | 10:48 AM
JasonERF's Avatar
Ah, yes. Thanks!
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
sadepol01
Sep 11, 2015 05:26 AM
