Drivers side speakers
Old Oct 31, 2008 | 10:38 AM
Mago304's Avatar
Default Drivers side speakers
I have a 02 xtype and for some reason all my speakers on the drivers side (american) have gone out. The passengers side works fine. Does anyone have any idea what it could be. I pulled out my radio and tried to reconnect the harness in the back but it didnt make a difference.
Old Oct 31, 2008 | 11:17 AM
The Chris X's Avatar
Default RE: Drivers side speakers
I've heard of this problem before. Did you check your door speaker connections at the speaker?
Old Oct 31, 2008 | 02:29 PM
SpartanX's Avatar
Time to buy new speakers. It would take a lot for the connection to become undone in the door panel. I got a set of MB Quart speakers for the entire car from aquill1. They sound a helluva lot better.
Old Nov 1, 2008 | 10:54 AM
rosemont83's Avatar
How much for the speakers spartan?
Old Nov 1, 2008 | 01:30 PM
Mago304's Avatar
I will buy new speakers if I have to, however there must be some other problem. It doesnt make sense that all the speakers would go bad at the same time. Is their a fuse that would control the speakers on that side of the car?
Old Nov 1, 2008 | 04:00 PM
Green Machine's Avatar
I agree with you the multiple speakers going out is not logical. If the problem is really with the speakers.
Looking at the JTIS schematic there aren't any fuses associated with the speakers only the wiring between the audio unit and speakers. Where you have wiring and connectors there is the possiblity of a bad connection so this is where I would be looking. Where to look I can't tell you because they don't show the routing of the wires. Since all your left side speakers are out I would think that the problem will have to be between the audio unit and the left front door post.
Of course worse case scenerio would be a problem with the audio unit itself.
Bob N
Old Nov 1, 2008 | 04:34 PM
aquill1's Avatar
Although not logical (it surely makes no sense to me[:@]) but there have been multiple people that profess that not just one but even all 4 have gone bad. Hey spartan I still haven't seen the speakers installed or how you like everything...
Old Nov 1, 2008 | 08:32 PM
jvegas's Avatar
could it be some type of amp going bad?
Old Nov 1, 2008 | 09:57 PM
aquill1's Avatar
To me or to mago?
If me, I assumed it would have to be an amp if all 4 speakers stopped working but I've been proven wrong so I don't know what gives???[sm=dontgetit.gif]
Old Nov 10, 2008 | 11:46 PM
kevin2050's Avatar
I have the same problem but the right side is not working for me. The tweeters are working but not the mids on the right side..(front and back). Seemed to do it all at once but it is possible that it went over time and I just didnt notice. I have repalced the head unit with a newer version with a CD polayer and I have the same problem . I have looked for an amp but my X-type 3.0 must not have that upgrade....looks like it's all running from "deck power". I have taken the panels off and have inspected the connections and all is fine...the only thing I have not done is try other speakers. I do have some that I think would fit but then I would have to splice the connectors and I just havent had the time to mess with it. I will let you know if that solves it...
Old Nov 11, 2008 | 06:31 AM
Brutal's Avatar
ok read everyones posts again, and go buy new speakers, theyre bad, 2 went you probobly didnt notice till the other went also. I replace Xtype speakers all the time for this. But if you prefer take it to the dealer, pay the 1 hour ck out fee to have them tell you the same thing we all have, or you can just paypal us all the $130 you save split up between all of us
Old Nov 11, 2008 | 02:46 PM
jjones91's Avatar
So what size are the speakers in the lower door?
Also, do you have to remove the entire door panel or simply pop off the speaker grill?
Old Nov 11, 2008 | 02:58 PM
Brutal's Avatar
IVE NEVER MEASURED, BUT YES THE DOOR PANEL HAS TO COME OFF
Old Nov 11, 2008 | 06:39 PM
christo's Avatar
At least try a speaker from the working side on the non-working side or hook the bad speaker to a good stereo. Could possibly be 2 channels crapped out. Either way, I have 2 stock front speakers, I believe they are alpine, I could ship them to you if you want.
Old Nov 12, 2008 | 07:11 AM
you may wish to try hooking up a new or known good speaker to the speaker leads for the bad speakers behind the head unit. It is easier, IMHO, to remove the head unit than the door panel. Peel back some of the wire sheath and hook up a couple of jumpers to test the leads. Then you can determine if it is the speakers/wiring to the door, or the head unit.
I have a break down of how to remove the unit and a pic of the wiring and description here: http://mydrive.roadfly.com/blog/ChrisX/
I still think it is the speakers.
Old Nov 13, 2008 | 11:22 AM
aquill1's Avatar
I say speakers are the problem...
Honestly the door panels are the easiest I've ever removed in my life. Just make sure you get every screw off and your set. I couldn't believe how easy the panel is to remove.
Old Nov 14, 2008 | 06:52 AM
I always end up braking a few of the plastic clip thingamabobs on the panel, since finesse is not one of my strong points. They are cheap, but still a PITA. I can pull the head unit on the X in less than 3 minutes.
sounds like speakers are the overwhelming favorite.
Old Nov 14, 2008 | 03:05 PM
paul11117606's Avatar
all my speakers went out a while ago, just buy new 6/12 speakers and stick them in, door panels come of easy but dont force them.
Old Nov 14, 2008 | 04:08 PM
aquill1's Avatar
Hey chris have you removed the panel on the x? It seriously is the easiest thing ever...i don't remember popping any of the door panel clips at all...it was a smooth flowing process just don't forget any screws!
