Dsc warning light fault
Old Jun 18, 2018 | 09:10 AM
rcrteammanager's Avatar
Default Dsc warning light fault
My Jaguar S Type 2.5ltr petrol Auto Reg 05 has a DSC warning message and lght fault.
I have had fitted a new wheel sensor which was diagnosed as faulty, new rear pads, new front discs & pads and new tie bars where necessary. I have had a new sensor fitted under the brake pedal which also was diagnosed as faulty.
After this I had 2 months without the warning lights/messge appearing then it appeared but was able to be cancelled by turning off the ignition for a few minutes and continuing the journey without the warnings reappearing. To date the warnings are there as soon as the ignition is turned on and the brake pedal is depressed to select a gear.
What is our next step ?
Old Jun 18, 2018 | 04:40 PM
Thermo's Avatar
Veteran: Navy
rcrteammanager, it is sounding like you need to have the codes read again to determine what code you have. It is possible you have a different wheel that has issues than the one your fixed earlier. It may be possible that you have a bad wheel bearing/reluctance ring and that is causing the sensor to not see the wheel spinning. This is where the C11X5 (where X will refer to the wheel in question that is failed) will help you narrow things down and not replace unneeded parts.
On a side note, you have put this message into the wrong forum. This may get a better answer if you placed it in the S-Type forum, not the X-Type Forum.
JimC64
Sep 22, 2025 02:52 PM
Lubrication
Oct 28, 2016 02:06 PM
Slam
F-Pace (X761) / C-X17
Oct 13, 2016 11:01 AM
IcyWhite02
Oct 12, 2016 08:51 AM
Tony Rainbird
Oct 2, 2016 01:00 PM
