ECU numbers
Old Aug 27, 2016 | 09:33 PM
Thang Nguyen's Avatar
Default ECU numbers
I need to buy an ECU for my 04 X-Type, but I can't afford to buy a new one. Thermo said I should buy one that made as close to my old ECU made date. Can any one explain all the numbers on the sticker at the bottom of X-Type ECU? I can understand some of them but not all. Or any one recommence some place repair Jaguar X-Type ECU? I found some place on line but they don't work with Jaguar ECU.
If I get an used ECU, is it have to be re-program, can I just take the ECU to the Jag. dealer? Or can I do it myself? I appreciated any suggestion.
Old Aug 28, 2016 | 06:25 AM
Paulc732's Avatar
Thang.
What makes you think its a bad ECU.
what is the build date of your car should be on a sticker inside the drivers door. also do you have the 2.5 or the 3.0?
Post your ECU numbers here someone may be able to decode them for you
Old Aug 28, 2016 | 09:41 AM
JagV8's Avatar
If E=Engine, they don't often fail and yes will need to match and dealer reprogram (if they can do it).
Old Aug 28, 2016 | 10:42 PM
Paulc732 I need to find the build date of the used ECU I'm going to buy, Not the build date of my car, Thanks any way.
klfong
Apr 7, 2016 05:51 PM
raze
Apr 2, 2016 12:13 PM
andyh1108
Apr 2, 2016 11:17 AM
Sights N Sounds
Jun 13, 2007 11:09 PM
Nov 30, 2006 11:15 AM
