Electrical faults.
Old Dec 15, 2019 | 07:22 AM
davidat19's Avatar
Default Electrical faults.
Now theres a surprise..
I have a 2006 X type diesel classic (?) ..the carbon fibre dash so a base model.
A few things...
I replaced the turbo actuator..having had it put on a professional reader (mine does nothing) it still takes a while to start and a few seconds to come out of limp.
Apparently it is showing no engine codes.
The off side (RH) dip beam keeps blowing fuses....I suspect the way round this is to connect it to the n/s lamp.
More irritatingly, I cant open the fluffing tailgate...it has moments but has usually rectified itself after a while..now it wont open at all. I cant hear the solenoid clicking in the tailgate..is this likely to need a new one? And am I going to be crawling into the back to get the cover off and swap it? Or is there another way to get the b*gger open?
I know..I should have looked while it was working...BTW, the glass doesn't open on this one...should it?
The other gripe is the o/s door mirror, managed to break it, bought a glass but it doesn't have the mountings on the rear...are they separate or do I need to get a main dealer one?
There you are..5 problems for the price of one...........
Old Dec 15, 2019 | 08:01 AM
DUNKS's Avatar
Hi cant help with your problems except to say my top of the range Sovereign has the carbon fibre dash!
Old Dec 15, 2019 | 08:39 AM
davidat19's Avatar
Well...we live and learn....but I still think mine is an economy jobbie....
Old Dec 18, 2019 | 02:26 PM
edtoo's Avatar
Yours must be an estate, the glass should open with the switch under the ridge below the rear wiper. The switch often has problems due to the ribbon cable wearing though or water ingress.
Old Dec 23, 2019 | 02:30 AM
davidat19's Avatar
yes..its an estate. As its a base I don't think the glass does open, but its the gate itself that lets me down.
I have now bought a s/h mechanism for it.
Old Dec 24, 2019 | 02:47 PM
edtoo's Avatar
Apologies I thought it was the tail glass that was causing issues. If the solenoid if clicking then the problem is in the mechanism. If it isn't opening at all then I would imagine it will be a messy strip down job.
The Door mirror should be the same as Ford mirrors and have the fitting attached to the back, if not you might need to strip the old glass from the fittings.
Old Dec 27, 2019 | 09:16 AM
davidat19's Avatar
Fitted a s/h lock mech....the tail gate glass mechanism is all there, ec=xcept for the switch under the rear wiper...it appears to be a solid piece.
Tail gate works, so hey ho! Now watch it fail!
Old Jan 10, 2020 | 07:08 AM
StevieG1234's Avatar
Default Interior light keeps coming on
Help
where do I start?
the interior light has been coming on for a while. I now have a warning that passenger door is open coming on at the same time.
bizzarly it seems that if I press the windscreen washer it triggers the fault.
any ideas
Old Jan 10, 2020 | 03:44 PM
davidat19's Avatar
Check your passenger door switch......
Old Jan 10, 2020 | 03:50 PM
Thanks I will try that
Old Jan 10, 2020 | 04:42 PM
Dell Gailey's Avatar
Spray some electrical cleaner/lube into the mechanism, then actuate it several times. Our Jags get gummed up after a while and the connections stick.
DGL
Aug 29, 2021 10:20 AM
DonSmith
Mar 21, 2016 04:13 PM
andymc1973
Jul 7, 2015 07:32 AM
OscarOtter
Mar 9, 2013 03:31 PM
briane100
Mar 6, 2010 09:08 AM
