Engine Misfiring
Old Aug 5, 2010 | 08:14 AM
rycymru's Avatar
Default Engine Misfiring
I have a 2002 X-type w/ 88k on it. I recently changed the spark plugs and i noticed that my gas mileage was not as good as it was before the change. I thought i might have not gapped them properly or i had knicked an electrode. So i pulled them out and put the app605 plugs in and now its idles rough. The engine has a little shake at idle, the power is reduced and my mileage has gone down significantly. I pulled the codes and got p0301, p0306, p1316; which is a misfire on cylinder 1 and 6, and misfire is causing incorrect emissions. What is the problem? Do i need new coils or a new sensor? Thank you for all your help.
Ryan
Old Aug 10, 2010 | 02:20 AM
Jessy's Avatar
I had this problem 2 months ago, what type of fuel are you using? Premium ? Regular?
Old Aug 10, 2010 | 02:46 AM
JagMaster's Avatar
new coils and use premium gas , i ve had the same issue.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
