engine system failure
Old Jun 26, 2014 | 07:55 PM
daniel3877's Avatar
Default engine system failure
About once a week this 2002 x type goes into like a down syndrome mode ..lol...sais engine system failure and won't rev over two grand...I pull it over and shut it off..start it back up and all is good....any one ever seen this ?
Old Jun 26, 2014 | 09:29 PM
Thermo's Avatar
Veteran: Navy
Daniel, yep, seen it. Odds are, you are looking at the throttle body motor requiring some work. If you get a new throttlebody, plan on spending about $1600 (oh, you want it installed, that is more). You can get a wrecking yard one for around $400 in a lot of cases and there is someone on e-bay that you can ship your throttle body to and for $400, they will rebuild it for you (granted, you car will be out of commission while the throttlebody is out of the car). You can also check the plugs on the throttle body to see if those are coming loose and/or you are getting water inside. You should also check the wiring going to the outside plug (nearest the strut tower) to make sure that the wiring insulation is not damaged.
If you are getting a check engine light (which you should be if it is restricting the engine), get the codes read and post them here as that might give us an idea of what is really going on. I am just going off of what I have seen with other vehicles.
Old Jun 26, 2014 | 09:33 PM
daniel3877's Avatar
OK.. thank you... will do.
Old Jul 8, 2014 | 06:52 AM
daniel3877's Avatar
Default update.. engine failure code
Quick update on this post.. I've taken this car to three different people with scanners... Only code that comes up is c1165 which spears to he rear right abs... in assuming either rear CV joint or abs sensor ? But no other codes present.. And my check engine light is on...I don't get it.. Any advice?
Old Jul 8, 2014 | 07:33 AM
Thermo's Avatar
Veteran: Navy
daniel, because you have the C1165 code, that will trigger the CEL. The rest of the engine is working as it should. It may be that you are having a second wheel act up (placing bets that if this is the case, it is the other rear wheel), the car gets confused as to whether the vehicle is moving or not (2 wheels are seen as moving, 2 are not). So, it puts the car into a restricted performance condition to give the operator a chance to get to a safe spot. So, I would say to first remove the ABS sensor on the rear wheel and see if you spot the reluctance ring at the base of the hole. Worst case, you will need a new CV axle. If you do some looking, you may be able to find only the reluctance ring on say e-bay. Fix that wheel and then see what you have at that point.
Old Jul 9, 2014 | 10:50 AM
daniel3877's Avatar
Is it possible that I have a bad sensor? I have two abs sensors that I had taken off a wrecked jag a while back
Old Jul 9, 2014 | 12:04 PM
Thermo's Avatar
Veteran: Navy
daniel, it is possible. This is where I would repair the one wheel and then see if a different wheel then pops up at that point. Odds are, what is wrong with the one wheel will be wrong with the second wheel.
Old Jul 9, 2014 | 03:31 PM
daniel3877's Avatar
If that ring looks all Rusty is it possible or beneficial to spray any type of a cleaner in there to freshin it up?
Old Jul 9, 2014 | 07:07 PM
Thermo's Avatar
Veteran: Navy
daniel, there isn't much of a ring there. so, not much to really recover once it is pretty well rusted.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
scottatl
Sep 4, 2015 08:08 PM
pocketrocket
Sep 3, 2015 07:44 PM
OkieTim
Sep 2, 2015 12:48 PM
