Engine system fault message
Old Oct 14, 2018 | 01:36 PM
Neil440's Avatar
Default Engine system fault message
2004 X-Type 3.0 engine does not start, all dash lights come on, battery is good, I turn the key and nothing. The message on the dash is ENGINE SYSTEM FAULT and TRANSMISSION FAULT. Any ideas.
Old Oct 14, 2018 | 03:03 PM
NBCat's Avatar
What is battery voltage across the terminals?
Old Oct 14, 2018 | 03:27 PM
Neil440's Avatar
I do not have a way of measuring that, the battery is only a few months old. this happened to me when I stopped at a gas station, after I wiggled all the electrical connectors I could find and rocked the car back and forth it started up and ran fine with no messages on the dash. This repeated 2 times and now it wont start. The gear shifter will not move out of park.
Old Oct 14, 2018 | 05:18 PM
NBCat's Avatar
Use a voltmeter to measure the voltage; it should be a minimum of 12.6 volts. Below 11.4, the starter may not run.
With the ignition on, what gear position lights up on the centre console?
Old Oct 14, 2018 | 05:20 PM
Originally Posted by Neil440
2004 x type 3.0l engine does not start, all dash lights come on ......
Welcome to the forum Neil440,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Oct 14, 2018 | 05:42 PM
Neil440's Avatar
nothing lights up on the dash to indicate what position the gear selector is in
Old Oct 14, 2018 | 06:26 PM
Dell Gailey's Avatar
Center consol is not the dash
Old Oct 14, 2018 | 06:36 PM
Neil440's Avatar
nothing lights up on the center console to indicate the position of the gear shifter, thanks Dell Gailey, do you have any ideas'
Old Oct 14, 2018 | 09:05 PM
JimC64
Sep 22, 2025 02:52 PM
Miss Charlee
Oct 5, 2016 07:03 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
Nov 29, 2005 10:42 PM
