exhaust swap
Old Aug 13, 2015 | 04:12 AM
philed's Avatar
Default exhaust swap
hi everyone, i have a 2.1 v6 petrol great looking car apart from one thing the rear end needs 2 tailpipes i was wondering if anyone had done or heard of someone that had transplanted a 2.5/3l twin exhaust from the front downpipes to tailpipes onto a 2l
Old Aug 13, 2015 | 01:42 PM
Justink201's Avatar
I've seen some that have done it on the UK based forum, most of us are in the US here and we didn't get the 2.1.
Old Aug 13, 2015 | 05:30 PM
wa3ra's Avatar
Looks like you'd need to fab up a downpipe, but everything else should be bolt-on!
Old Aug 15, 2015 | 06:07 AM
euanT's Avatar
Got mine done by a local custom fabricator, 2.0D, but same hidden pipe as the 2.1, much better!! Must be someone local in Kiwi land that could do something similar, stainless by the way!!
Old Aug 16, 2015 | 01:28 AM
philed's Avatar
that looks good will try round a few fabricators see what i can find did you replace the bumper or is it a custom cut out?
Old Aug 16, 2015 | 03:22 PM
euanT's Avatar
I have the facelift model, dont know if you got them in NZ, the lower valance I got from SNG Barratt, only £25.00UKP, quite cheap really!! it is the valance from the 2.6/3.0 petrol model, straight swap for mine, that had no cutouts!!
Old Aug 18, 2015 | 08:31 AM
X-Type_Bobstar's Avatar
I've also done this on my 2.2D, I fitted a 2.5/3.0 valance with the arches in it and had a custom rear section made up so I have a Y join by the rear wheels and a pipe to either side same at Euan T. The space is there and I'm sure a performance car place can do this for you.
Old Aug 18, 2015 | 10:20 AM
euanT's Avatar
Here is the "joint" in mine!! The fitter made it connect to the front section as normal, so I can fit a standard front section if required, but I wont!! next job is S/S front section with small silencer and De-Cat, quoted £200
Poet
Feb 7, 2025 02:18 PM
hoodun
Nov 20, 2022 02:35 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
vwbusbits
Oct 13, 2015 03:43 AM
Woznaldo
Sep 26, 2015 11:02 AM
